diyAudio Sponsor
Old 9th February 2006, 03:39 AM   #11
Well, scratch that. I fully intended on winning the ebay auctuion but I was about to put in what I thought would be a high enough last-minute bid when it got higher than I planned.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5861981544
Now that I'm looking at the schematic (which is for the MX30, not the MX30A, but it should be close enough), I see that all the tubes actually appear to be there. I figured the empty 9-pin sockets right next to the inputs were tube sockets, perhaps I was wrong? The only verification I got for missing tubes was from a guy on a car forum.
Maybe I should have posted the ebay link earlier. Ah well, too late now. I wish I would have checked emails before I logged on to ebay tonight, knowing all the tubes were there would have compelled me to pay a fair bit more for it. I guess I'm back in the hunt. Thanks.
By the way, how long does it take for your posts to stop being "moderated" when you're a new member?
-Darren
Old 9th February 2006, 11:49 AM   #12
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Don't worry, it probably wasn't the best candidate for a guitar amp conversion anyway. Look out for a more standard one, maybe a 6L6 push-pull or similar with 4-8-16 ohm outputs. I once got two old PA amps, with tubes, for about $20.
Maybe have a look around old junk stores in your neighbourhood, or ask some old ham radio guys.
Old 9th February 2006, 04:18 PM   #13
Okay, back in business! Check out what I just scored!
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5864748037
And so the fun begins. Anyone have the schematic for the M60A? Thanks.
Old 9th February 2006, 04:35 PM   #14
Send a message via AIM to DigitalJunkie
The sockets next to the inputs were probably for input transformers.
On a similar note,
I have a "gutted" chassis+output trans. from a Bogen M120 that I was thinking of building a "bass" amp with (meaning bass guitar,and possibly subwoofer duty also.)
Does anyone have the schematic of the M120? There's some interesting windings on the OPT,and I havn't figured out what they're for yet..(seperate feedback winding,and a 70V output,perhaps?)
I found the plate and speaker leads,and I've crudely figured the impedance to be approx 3.5K. (can anyone confirm this?)
</thread jacking>
Old 9th February 2006, 06:26 PM   #15
Tom Bavis's Avatar
M120 is not listed in Sams index. But Bogen is still in business - I have heard that they sometimes will provide info on their older products...
M60A is not in Sams either. But..
M60 is in 488-5
MX60 is 482-6
MX60A is in 891-Servicer (probably schematic only)
Your library may be able to get these, or try Walt at infotronix.us or Bob at findatube.com
Old 9th February 2006, 10:08 PM   #16
Do you guys think one of these would be a worthwhile investment?
http://www.tech-wiz.org/store/view_p...1bba1896099290
Old 10th February 2006, 04:58 AM   #17
Enzo is offline Enzo  United States
That seems like for a schematic to me.
Go over to Ampage and ask in the guitar amp forum if someone has that schematic. They often discuss rebuilding Bogens into guitar amps, it is a popular project. It is a forum devoted to guitar amp building and tweaking.
Schematic Heaven would be worth checking but they seem to be down lately.
http://www.ampage.org
Old 10th February 2006, 04:39 PM   #18
oops.
It appears that the M60A uses 8417 power tubes, which haven't been in production since 1988. Looks like I have to pray the tubes in there still have a lot of life left.
I searched around for other tubes to convert it to, and it looks like the 6550 is the ideal option. Does anyone have any suggestions on how to do this? Thanks.
-Darren
Old 10th February 2006, 06:16 PM   #19
Dave Cigna's Avatar
I once had a MO-100A (quad 8417) on the bench. For giggles I measured the primary impedance of the output transformer and found it to be about 4.5k. If the MO-60A is similar, but with just a pair of 8417 then I would expect the primary Z to be about 9k.
9k is pretty high if you wanted to try other output tubes. The good news is that guitars only go down to about 80Hz, so you can easily get away with putting an 8 ohm speaker on the 4 ohm tap to get a 4.5k load. That's not too far from where most 40W or 50W amps run class AB pentodes (ie 6L6/EL34/KT66.) 6550 and KT88 ought to be pretty happy there too.
On the other hand, you might really like a 9k load. I understand that the early 50W marshalls used something like 7k or 8k on a pair of KT66/5881/EL34 and nobody ever complained about the sound of those amps!
-- Dave
edit: errrp, I should have said put an 8 ohm speaker on the 16 ohm tap.
Old 10th February 2006, 10:08 PM   #20
I'm probably getting ahead of myself worrying about the tubes, but when you buy something untested off of ebay, you always have to assume the worst .
Anyway, do output tubes have to be the same brand? I found a few 8417s on ebay, and after an hour of searching, that's the best I'm probably going to get. I could't find any tube pairs, only single NOS tubes and they are all different brands. I'm just wondering if brand mattered, because it might not be a bad idea to snag one or two as backups anyway.
A guy on Ampage said that the schematic of the M60A is almost identical to that of the CHB-50. Can anyone give me a schematic of that one? Thanks.
-Darren
Bogen M330A Tube PA Amp for Guitar zeke Tubes / Valves 28 6th December 2009 07:58 AM
bogen mx-60a tube pa amp guitar ElectricMan Swap Meet 1 3rd May 2009 03:02 AM
Bogen J130 PA to guitar amp? bigaldo Tubes / Valves 0 18th February 2008 05:36 AM
Bogen H-30 guitar mod tgrizzle Tubes / Valves 5 14th April 2007 11:50 PM
Bogen K15 convert to guitar amp tonemonster Tubes / Valves 0 29th March 2007 09:11 PM
Page generated in 0.13440 seconds (69.26% PHP - 30.74% MySQL) with 11 queries
