diyAudio Sponsor
Old 5th April 2006, 02:41 AM   #101
This sucks.
So I got all my new caps. I got the cathode bypass caps replaced (painful) as well as one of the external filter caps (literally painful - burnt a little insulation on the power tube plate supply wires, that smoke stings when it gets in your eyes!) and now I've got the other external filter and the can out. Now I'm not sure how I'm going to put in the new individual caps. My original plan was to mount a terminal strip on the outside right next to the original can hole and wire everything to that so I could mount the new caps externally, but now I realize there isn't enough slack wire to do that. There isn't enough room under the chassis for more caps, and I don't know what to do.
Bogen M330A Tube PA Amp for Guitar zeke Tubes / Valves 28 6th December 2009 07:58 AM
bogen mx-60a tube pa amp guitar ElectricMan Swap Meet 1 3rd May 2009 03:02 AM
Bogen J130 PA to guitar amp? bigaldo Tubes / Valves 0 18th February 2008 05:36 AM
Bogen H-30 guitar mod tgrizzle Tubes / Valves 5 14th April 2007 11:50 PM
Bogen K15 convert to guitar amp tonemonster Tubes / Valves 0 29th March 2007 09:11 PM
Page generated in 0.07701 seconds (67.06% PHP - 32.94% MySQL) with 11 queries
