Hybrid amplifier help...
Old 20th February 2006, 12:08 PM   #81
DoomPixie is offline DoomPixie  Wales
Send a message via MSN to DoomPixie
i understand now.. i will look into it some more..
Thanks,
Owen
Old 20th February 2006, 12:12 PM   #82
sajti is offline sajti  Hungary
Thanks,
Owen
Just add a DC servo, to apply DC feedback. It will solve the problem, and You can use this topology
sajti
Old 20th February 2006, 01:59 PM   #83
anatech is offline anatech  Canada
anatech's Avatar
Hi Owen,
Before trying a DC servo, just reference the input to ground as I mentioned. I have a circuit that is similar that I didn't get over a 50mV DC offset. I left it because other examples sat around 10 mV DC. I didn't get an on or off spike either. This could be as esy as a pair of 220K resistors from each input to ground.
The common resistor ensures equal current flow in the ccs reference diodes, match the emitter resistors. I also matched the input transistors for gain.
-Chris
Old 20th February 2006, 02:28 PM   #84
thanks for clearing that up chris, I was planning on building the circuit as is and testing it before adding a dc servo (if it is really needed) Would rather get it workign before i overcomplicate it. I would probably have a working prototype now.. but i found that the battery in my multimeter is flat when i went to turn it on earler to measure soem resistors must have left it on or something
anyway,
i will get a new battery tommorow hopefully.
Wish me luck..lol..
Thanks,
OWen
Hybrid amplifier help...Hide this!Advertise here!
Hybrid amplifier A2 class Jaime Tubes / Valves 16 20th June 2012 11:39 PM
The Hybrid Class A amplifier gaborbela Tubes / Valves 135 24th May 2012 06:33 PM
amplifier for hybrid car? star882 Car Audio 8 24th May 2009 05:50 AM
The Perfect Hybrid Amplifier Stee Solid State 0 27th July 2008 09:03 PM
Hybrid amplifier.. Please help.. DoomPixie Solid State 96 2nd March 2006 03:54 PM
