diyAudio Sponsor
Old 7th February 2006, 11:18 AM   #1
Default musical fidelity f22 schematic wanted
its a tube preamp with 4 6922s I think, anyone either traced the circuit or have a schematic please, thanks
Old 9th August 2006, 11:08 AM   #2
andrew_whitham's Avatar
Default f22
Hi, If you do (or did) manage to get a schematic, please share!
Meanwhile, if it helps, yes it does indeed have 4 JAN 6922's inside, also printed neatly on the board is 'class A balanced linear cascode F22 preamplifier'
When I re-capped mine I took (before) pictures, but only of the top of the board (No I dont know why either.) if those are useful?
Cheers
Andy
musical fidelity x10d schematic arvin Tubes / Valves 45 31st August 2011 09:50 AM
Musical Fidelity B1 Schematic (does anyone have one?) Thomo Solid State 11 7th July 2009 09:16 PM
Musical Fidelity X-PRE schematic Bem-bem Tubes / Valves 2 27th May 2007 08:19 AM
Musical Fidelity F16 problem/Schematic Smiffy Solid State 8 10th December 2006 04:39 PM
musical fidelity kw phono schematic here... lt cdr data Analogue Source 10 2nd November 2006 09:22 AM
Page generated in 0.05798 seconds (68.53% PHP - 31.47% MySQL) with 10 queries
