| diyAudio Sponsor | ||
Hi all,
I'm building, very very slowly, THIS tube amplifier. I'm actually building the power supply (that will be a separate unit). When the power supply will be ready I will begin to build the amplifier. I'm collecting material, and I found a surplus stock of 2microfarad, 2000V paper in oil capacitors (VERY big) I would like to use as output capacitor. So, my question is: how can I calculate the needed capacitance? I was thinking to use 4 microfarad (as for the schematic): is it enough? I'm not sure I will use any feedback, so forget it for the moment. Thanks in advance, Giovanni
In Nomine Libertatis Vincula Edificamus, In Nomine Veritatis Mendacia Efferimus. |
#2 |
Hi ,
1 ) In my opinion, paper caps are not suitable for output coupling due its high inductance 2) There is an error in the feedback connection ( +B is turning back to the first cathode 3) The capacitor value is very dependent of the primary impedan- ce and inductance 4 ) As a rule of thumb , you can use C= 1.6 x 10e6 / f1 x Zp ( in uf ) If f1=20 Hz ( good enough ) and Zp= 5000 ohms ( hypothesis ) C= 16 uf you can use electrolytic caps Regards Carlos |
#3 |
For good Phase response down to 20Hz you usually put your -3dB point around 3Hz to 6Hz range...
What is the transformer info??? Turns ratio, inductance, secondary termination load....ect.. Chris |
#4 |
Thanks for the answers.
Refference: Yes, there is a mistake in my schematic, thanks a lot. The feedback should be connected by a capacitor the the first cathode, not directy. What about polypropilene motor capacitors? I have a lot of them. I'm using toroidal transformers as OPT, I do not have too much characteristics: they have a niominal power of about 80VA, a turns ratio of about 25.5 (230/9V), and that's all. Thanks again, Giovanni
#5 | |
Sheldon |
#6 |
1 ) Polypropilene motor capacitors , are a better choice than paper caps , you can try them , and as sheldon said , if they are rated for 440 VAC or more , they are fine until 650 VDC ( +B ) 2 ) With the turns ratio that you gave (230/9 VAC) , the Zp ( primary load ) will be 5200 ohms for a secondary load of 8 ohms , then C= 16 uf is OK !! 3 ) Don't forget the first cathode has an impedance of aprox. 47 K ohms ( before R6/R9 ), then you have to use a 2 uf cap , rated for +B x 1.5 Volts minimum . or try to connect the N.F. to secondary winding ( you need to verify the phase of output signal ( be careful !! ) Regards Carlos |
#7 | |
John |
#8 | |
#9 |
Thanks to all for your answers.
I have a lot of 1 microfarad, 4 microfarads, 450Vac polypropilene motor run and flourescent lamps (used for PFC) capacitor... I will use them for the input and the interconnection stage. I just found some high voltage electrolytic capacitor (100 microfarad), used to start motors. I will try them as output capacitor too. Ciao, Giovanni
| Best output Capacitor | gearheadgene | Class D | 12 | 8th January 2009 09:28 PM |
| PLH output capacitor rating | gbullimore | Pass Labs | 1 | 4th October 2007 09:42 PM |
| Output Capacitor Value | dr._sleep | Tubes / Valves | 11 | 9th February 2006 05:24 PM |
| Question about output capacitor. | Tomek | Solid State | 18 | 22nd August 2003 07:41 AM |
| Output capacitor in Zen 4 | Buhl | Pass Labs | 3 | 20th November 2002 02:45 PM |
| Page generated in 0.09569 seconds (81.01% PHP - 18.99% MySQL) with 10 queries |
