diyAudio Sponsor
Old 6th February 2006, 10:42 PM   #11
diyAudio Moderator Emeritus
ray_moth's Avatar
Your 6V6GTs will make good output stages for modest power ~ 10watt in push-pull. A lot of guitar pratice amps use those.
The 6AU6 is a sharp cut-off RF pentode that is suitable for audio use. It can be used as a normal voltage amplifier in pentode mode, in triode mode with g2 and g3 strapped to plate, or in triode mode using g2 as anode and with g3 and plate grounded (small signals only). The 6AU6 is also good as a constant current source/sink,
Old 9th March 2010, 04:21 PM   #12
DrRick is offline DrRick  United States
I've seen the EF50 used as the input tube in a SHT SE amp. It was on Tossie's Japanese sit, I think.
I have about a dozen of them myself.
Does anyone know where I can get some sockets for them? It's a 9 (nine) pin loctal.
Peace,
DrRick
Peace,
DrRick
Tube Noob! need help with tubes lots of tubes therapy_fan Tubes / Valves 15 29th January 2009 10:01 PM
WTT: Various tubes for 6CA4/EZ81 rectifier tubes GordonW Swap Meet 4 27th August 2008 01:37 AM
Audio Switcher involving Optical and Stereo In, 5.1 Out hsadan Parts 0 4th July 2007 02:34 PM
Need help with a project involving solar cells and SLAs Saturnus Power Supplies 24 27th July 2006 05:06 AM
Page generated in 0.07668 seconds (66.40% PHP - 33.60% MySQL) with 10 queries
