| diyAudio Sponsor | ||
I'd like to pick the brains of the veteran builders here. Where do you start when you go from a schematic to an actual functioning circuit?
I know there are many factors that are important. Among them are: proper grounding, isolation of stray AC from signal paths, minimizing unwanted stray capacitance, proper ventilation and heat control, and so forth. My question is - where do you begin? Your tips on the most logical sequence of layout and construction would be GREATLY appreciated. |
#2 |
What are you building?
#3 |
Well, I'm considering building several things, as time permits. I've been accumulating parts at a pretty good rate, and now I have lots of options for projects to build.
Things I'm most interested in at the moment: -An Aikido headphone amp, perhaps with subminis, maybe with octals - A 6K6 SE power amp - A dual-6C4 SOHA headphone amp with an iPod dock - An all-ST tube 5U4G/OD3/6F8G/ 6BG6G PP power amp Many other boxes of parts and interesting schematics are lying in wait to abscond with all my free time. |
#4 |
Decide on where the big lumps should be first of all. I often arrange them and leave them there for a few days while I decide whether I like the arrangement. Rotate your valve sockets so that the heater pins are nearest to the edge of the chassis. Think about hum fields from transformer and heat from valves. Arrange stuff so that the signal from the input socket only goes an inch or two to the first component then flows around naturally so the output of the amplifier is nice and near to the output sockets. Screened lead is verboten. Think about heat and magnetic fields all over again. Now make it pretty.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#5 |
Big question.........................
One thing that has always been a constant for me is starting with a very clean schematic. Not to say that there isn't a million other things to consider in physical layout, but a good physical layout springs from clean schematic. By a clean schematic, I mean a minimum of intersecting wires (crossovers etc...), and a logical flow of signals. This may apply more to PCB design... but it has bearing on P to P wiring as well. I suppose another big thing is do your work on paper first... you can do this in CAD. but you can also cut up life size "puppets" from graph paper and work on your arrangments then. It doesn't take as long as you think to cut out all the shapes. Landscapers and architects do the same thing. Make your mistakes on paper. The nice thing is, if you carry this method to it's extreme, you can, for example, do all your drilling and cutting on a chassis all in one session. It goes faster, you make less mistakes, makes it look to others like you really know what your doing, but most importantly it keeps you from drilling and cutting on a chassis or PCB that is already half full of parts. Metal chips and shavings don't mix well with electricity, and these little bits can find their way into places and not find their way out. |
#6 |
Absolutely. A well-drawn circuit diagram leads naturally to a good mechanical layout. I would second every one of poobah's points.
| TH project. Need help with actual layout. | FlipC | Subwoofers | 1 | 29th October 2008 10:17 PM |
| NEW schematic layout | bracoraab | Solid State | 11 | 29th January 2008 07:16 PM |
| need a signal generator pcb layout or schematic | hizz_eye | Solid State | 8 | 3rd March 2005 06:09 PM |
| Denon PMA 770 - Schematic & PCB layout - Anyone got one? | GeorgeBoles | Solid State | 1 | 29th September 2004 11:50 PM |
| Does anyone have a schematic or pcb layout for eq | punchpeanut | Parts | 3 | 22nd September 2003 08:20 AM |
| Page generated in 0.08993 seconds (75.54% PHP - 24.46% MySQL) with 10 queries |
