| diyAudio Sponsor | ||
#11 |
First I must warn you that I am not a friend of hybrid designs so I can't add so much help with your chosen circuit but I am intrigued why you want to build such a complicated design so I would be intrested to hear your answers to some questions I have. Why do you use such big tubes as EL 509 to drive headphones? What is your basic goal? is it to build a headphone amp as such or is to build a hybrid amp? How much output power do you aim for? I built a much simpler amp that can be seen here http://www.tubetvr.com/headphoneamp.html it gives about 600mV out when loaded with 30 ohm load which is about 12mW and more than enough for most headphones. Regards hans |
#12 |
Hi Tubes4e4 & Hans,
Thanks for replay, I really need some feedback from more experience builders around. I will use PL509 (or PL504, if I can get them) 'couse I allready have 16 pcs of them, and the very same topology will be eventually used for power amp. I will try to build a headamp first to evaluate topology soundwise, it's chiper that way. Why hybrid? Becouse it's DC coupled balance amp, from input to output, and that is what I like (although one might see a servo opamps as capacitor), and except topology from Kaneda (also hybrid, totem-pole SE output, I think) is the only one I have found out so far. Headamp should be capable to drive 32 and 300 Ohms headphones simultaneously, so something like 2W in class A
Non é mai abbastanza... |
#13 | ||
Regards Hans |
#14 |
Hi Hans,
I am aware of the power needed to drive heaphones to ear spliting level, I can only confirm yours findings, but I forget to note that Headzilla will be eventualy used as a speaker/tweeter amp also in biamp system just to evaluate concept soundwise before I go for OTLzilla DC coupled instrumentation amps with tubes, newer heard for such, any link before I hit the Google? Best, a P.S How about all valve (PCC88) DC coupled (from input to output) balance headamp with Circlotron topology, is it posible?
#15 | ||
Although a DC coupled balanced OTL is possible to design maybe you should take a step back and think about what your requirements are? What are the advantages that you think you will get with an all DC coupled design? will it give any noticable difference compared with a simpler design where you use a few coupling capacitors? The same for why you want to use an all balanced design, what are you trying to achieve and will it give any noticeable difference? Regards Hans |
#16 | ||
Hi Hans,
Best, a
| capacitor coupled vs. direct coupled ouput | hugobross | Solid State | 11 | 21st January 2011 02:56 AM |
| 6sn7 direct coupled and transformer coupled | neazoi | Tubes / Valves | 3 | 23rd May 2008 04:30 PM |
| My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. | Spasticteapot | Multi-Way | 0 | 30th November 2006 05:16 AM |
| Coupled or de-coupled cabinents | troystg | Multi-Way | 12 | 20th October 2004 11:34 PM |
| Can someone explain parafeed & direct coupled & a.c. coupled? | mwmitchell | Tubes / Valves | 2 | 11th September 2002 02:10 PM |
| Page generated in 0.09465 seconds (86.43% PHP - 13.57% MySQL) with 11 queries |
