diyAudio Sponsor
Old 4th February 2006, 07:33 PM   #1
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Default negative voltage doubler for ccs
I want to use a Pimm CCS under the cathodes of a el84PP amp. I only have a free 5 volt tap on my transformer. So I thought about a voltage doubler for the negative supply under the CCS.
I suppose that i cannot connect the bottom of the CCS to earth.
I do not know how to make that negative voltage doubler.
Anyone ? Thanks !
Old 4th February 2006, 08:52 PM   #2
Jaap,
The "full wave" doubler circuit is differential. You can treat either end as "hot".
Connect the cathode of a Schottky diode and the anode of a 2nd Schottky diode to an end of the 5 VAC winding. Connect the free cathode to the + terminal of the doubler cap. stack. Connect the free anode to the - end of the doubler stack. Connect the free end of the 5 VAC winding to the center of the doubler stack.
Use BIG caps. in the doubler stack. Follow the doubler stack with a choke and more capacitance. Available DC current will be approx. 1/4 the AC RMS value. The rail voltage will be slightly above 12.5 V.
Eli D.
Old 5th February 2006, 12:24 AM   #3
leadbelly's Avatar
Just for my own understanding, Gary Pimm told me the CCS typically has 30V drop across it. Does that mean your cathode will be biased up to about +20V?
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 5th February 2006, 08:37 AM   #4
Jaap's Avatar
Default :whazzat:
thanks for the useful information about the doubler.
I didnot realize that the voltage drop could be that big around the Pimm-ccs.
I saw ccs with -15 volt under them, so I figured I could try with my 5 volt transformertap.
Perhaps i have to use a different ccs under the el84 (?)
Old 5th February 2006, 09:38 AM   #5
Shoog's Avatar
In this role why not consider a simple LM317 regulator. Its a far less demanding position for a CCS than an anode load and I understand these regulators work well in this position.
Shoog
Old 5th February 2006, 12:44 PM   #6
Dave Cigna's Avatar
You could probably get away with a cascode mosfet ccs there.
But, a negative supply is needed only if you want to keep the grids at ground - at the input stage for example. Are your el84's cap coupled? If so you can bias the grids positive (derived from B+) and forget about the negative supply entirely.
-- Dave
Old 6th February 2006, 05:32 AM   #7
2wo is offline 2wo  United States
Try This...John
this
All tube voltage doubler Steven-H Tubes / Valves 16 8th July 2011 12:02 PM
Need help with voltage doubler Lingwendil Power Supplies 6 22nd April 2009 12:15 AM
Voltage Doubler jwatts Tubes / Valves 3 2nd January 2009 12:13 AM
Voltage doubler Baard Solid State 28 17th January 2005 04:46 AM
Page generated in 0.09415 seconds (76.74% PHP - 23.26% MySQL) with 10 queries
