diyAudio Sponsor
Old 4th February 2006, 03:50 AM   #1
Default Re:preamp sputtering noise
Hi there ,
Bought a valves preamp it consist of two 12ax7 and two 12au7 with diodes retifier of Ebay .
Test it it has sputtering noise on one channel with all tubes pull out or plug on
it get louder as the volume turn up
Wonder where to start could it be a short circuit at the pot
or ....??need help
cheers
Old 4th February 2006, 09:17 AM   #2
sbrads is offline sbrads  United Kingdom
If it's new then it's most likely a poor solder joint. Just have a good look for nice joints that have flowed, i.e. the components were 'wet' with the solder when it was molten and have a shape that looks like it was once wet with a meniscus.
If you don't get anywhere with just looking, try tapping components with a plastic biro to see if the noise changes. I always wear thin gloves when I do such things >100volts.
Old 4th February 2006, 09:30 AM   #3
Hi sbrads
It a old preamp built by Sound Audio Limited ..
Allergro Tube Line amplifier Model -18.
I
t has six 1000uf 250volts capacitor which four of them are bulge look like they going to blown
would that be the case.
Cheers
Old 4th February 2006, 04:01 PM   #4
You've answered your own question. New caps throughout methinks.
Old 4th February 2006, 04:17 PM   #5
poobah is offline poobah  United States
poobah's Avatar
Yup...
Old 4th February 2006, 06:07 PM   #6
Default Thanks you guys
Cheers
New capacitor on it way
help! annoying preamp noise strangecargo Everything Else 4 9th September 2010 06:55 PM
Help on NE5532 preamp Noise FREE pra3718 Chip Amps 20 19th March 2009 09:22 AM
Radio Shack preamp noise Mike Riley Parts 2 18th June 2007 03:29 PM
what causes noise in a SS preamp? woodturner-fran Solid State 5 27th May 2007 10:33 AM
Preamp hiss noise morfeas Tubes / Valves 10 17th June 2005 04:52 AM
Page generated in 0.07574 seconds (75.36% PHP - 24.64% MySQL) with 10 queries
