| diyAudio Sponsor | ||
#11 |
Holy overkill batman!
Ever considered using something like an 83 instead? |
#12 | |
Certainly true if are only after the blue glow. If, otoh, you also care about the sound you might find no other rectifier sounds so good. |
#13 |
Thanks everyone, I cant wait to test these things!
Cheers Craig |
#14 |
Chris,
My 'good' tester is a Stark 9-66. I am quite sure it has a 5U4 inside, but it has been a very long time since I looked. What Hg rectifier type is in yours? Aren't they arranged horizontally in that tester? That would be a no-no for the larger Hg tubes. I know there was a smallish Hg full wave (dual) rectifier made like a 5Y3 or 80, called a 82 and 83. I have one or two of these NIB.
I.Q.Test. Have you ever purchased a recreational snowmobile? |
#15 |
Craig,
That big rectifier tube you have appears to be about the same size as a 572. That is a powerful rectifier good for 1.25 Amps continuous. Max voltage drop is listed as 10 volts. The 572 needs 5 volts at 7.5 amps on the heater/cathode. The tube needs a minimum of 5 minutes to reach operating temperature before anode voltage can be safely applied. I do not know for sure that you have a 572 type. I have some and yours looks quite similar.
#16 |
Hi Rob,
Indeed, your Stark should use an 83 rectifier in it. It is mounted horizonally. I have the schematic somewhere for it if you need. The other tube is a 5Y3. It has a *.DJU extension, so I can't attach it. -Chris |
#17 |
i have used the 83 in my 300b amps and also 866 in a preamp (i know, overkill. pic attached below.).
just remember to warm the filaments before applying B+ (sakuma san's circuits also has a delay switch on B+ when 83s are used. delay also recommended as per tube datasheet recommendation.). you can do this with dedicated power trans to the rectifier's filaments or using a double pole triple throw switch.
| Tannoy mercury Mk2 | cmitch | Multi-Way | 2 | 2nd February 2009 04:45 AM |
| Water vapour speaker? | bigwill | Planars & Exotics | 4 | 31st May 2007 09:29 PM |
| Using 866A Mercury Vapour Rectifiers? | SHiFTY | Tubes / Valves | 18 | 28th January 2005 03:29 AM |
| Mercury rectifiers | gimpus | Tubes / Valves | 11 | 26th April 2002 03:59 PM |
| Page generated in 0.09987 seconds (73.49% PHP - 26.51% MySQL) with 11 queries |
