diyAudio Sponsor
Old 3rd February 2006, 11:29 AM   #1
Default lookin for a tube buffer
hi ,,
i built the real mctube for my bass guitar ,
the circuit s here :
http://www.dogstar.dantimax.dk/tubestuf/mctube.htm
i need a tube buffer for this preamp to use a tone control after that ...
the only tubes i have to use in buffer is : 6av6 and 12ax7 ...
any circuit ?
Rest my eyes from the world.
This dying place, it's so absurd.
Old 3rd February 2006, 10:43 PM   #2
The triode in a 6AV6 is the same as the triodes in a 12AX7. IMO, that triode makes a poor buffer due to low transconductance (gm). You easily might do better using a FET voltage follower.
Eli D.
Old 4th February 2006, 08:00 AM   #3
i wanted to use a FET buffer ...
but one of my friend told me if i m using a tube pre amp better to use a tube buffer , but i couldn t ask him how ...
Old 4th February 2006, 12:27 PM   #4
IMO, your friend's concern is misplaced. Tubes and FETs work very well together. FET's make GOOD current amplifiers. Think of a FET as being a heaterless pentode.
Eli D.
Tube buffer before pre-amp/amp? Destroyer OS. Instruments and Amps 2 9th January 2009 07:09 PM
tube buffer values trancy Chip Amps 12 29th February 2004 11:09 AM
Tube Buffer for guitar set up SorenKorsgaard Instruments and Amps 0 18th January 2004 03:21 PM
Tube Buffer IGC - need help .... Will Chip Amps 22 21st November 2003 07:54 AM
Tube buffer NickC Tubes / Valves 3 9th May 2002 11:20 AM
Page generated in 0.06858 seconds (71.72% PHP - 28.28% MySQL) with 10 queries
