diyAudio Sponsor
Old 2nd February 2006, 11:32 AM   #1
Default Oil Filled Capacitor not upright OK?
As above, do I have to fix it in a upright on the chassis or lying down inside is fine?
thx!
Old 2nd February 2006, 11:52 AM   #2
think that depends radial and axial versions???
think radial versions have to be uprigt....
emission over emittor
Old 2nd February 2006, 12:22 PM   #3
Sherman is offline Sherman  United States
If you are talking about motor-run type caps they are perfectly happy mounted horizontally. As for other types, I don't know.
--Sherman
Old 2nd February 2006, 02:08 PM   #4
I'm not really sure, it looks like this... <attached> If it's the "upright only" type, which direction is fine, as long as it's upright, correct?
p.s. I can hear some slushing when I shake it, I presume it's the oil inside...
Old 2nd February 2006, 07:04 PM   #5
That looks like a motor run cap. You should be able to mount it pretty much any way you want.
I've mounted mine vertically (upright) sticking through the top plate of the amp because they take up less room that way. If you don't like them protruding like that you can mount them horizontally inside the chassis.
They can be held in place horizontally with wire-ties but a nice method is to use a conduit clamp. They have a flat side that can be attached to the chassis with a screw and a round section that holds the cap. They are available in sizes from about 1/2" up to about 3".
--Sherman
oil filled capacitor jaudio Parts 5 11th November 2006 10:36 PM
Why Don't All Mids/Midbasses Have Flat, Filled-In Cones? kelticwizard Multi-Way 90 11th June 2004 12:51 PM
Hermetically sealed Oil Filled resistors! Layberinthius Tubes / Valves 14 28th April 2004 01:53 PM
Oil Filled Transformers for BOZ and Valve Preamps mozfet Swap Meet 3 31st October 2002 10:13 AM
Page generated in 0.06994 seconds (71.23% PHP - 28.77% MySQL) with 11 queries
