diyAudio Sponsor
Old 2nd February 2006, 11:26 AM   #1
Default Aikido using a #26 tube?
Ok, given the formula for figuring the second half of an Aikido circuit could a #26 Aikido be made? Anyone that has played with a #26 tube can tell you of the hum associated with it and the need for a battery heater supply.
Would the Aikido circuit therefore be capable of nulling the hum factor without using the battery and charger setup?
Wouldn't this make a nice diy project?
Old 2nd February 2006, 04:30 PM   #2
kevinkr's Avatar
check out my article on a 26 transformer coupled pre-amp at Positive Feedback online or go to my website where you will see most of the sameinformation..
http://www.kta-hifi.net/
The problems you are likely to have with the 26 revolve around its high microphony, doing good 1.5V dc filaments supplies is relatively easy.
Transformer coupling works very well with this type and because of the low overall gain mechanical disturbances are not amplified as much as would be the case for RC coupled designs.
I would seriously recommend anyone using these or the 01A mount them on a mechanically isolated (soft rubber bushings) subchassis in their pre-amp design.
Note that they are also quite sensitive to external electrostatic fields and benefit from shielding. (I use cheap copper foil cans around mine.)
Kevin
www.kta-hifi.net
Old 2nd February 2006, 10:08 PM   #3
Anyone that has played with a #26 tube can tell you of the hum associated with it and the need for a battery heater supply.>
Well, I thought that until I connected one side of my balanced 26 line stage to SLA batteries and the other side to a Thurlby Thandar PL154 bench power supply (0-15v, 4A). On my system hum was practically non existant on the bench supply and the sound quality was virtually identical. My speakers are Monacor SPH-130AL single aluminium 5" drivers, sensitivity listed at 88db. the line stage handles the output from my DAC digital board.
So, in these circumstances, I feel confident you could use a well filtered DC supply. My line stage is balanced - no idea if that lowers hum but I doubt it. There is a very low level of hum, by which I mean barely audible with your ear against the cone. Whether this would be a worry on a high efficiency horn I can't say. No hum on the batteries. Andy
Old 2nd February 2006, 10:41 PM   #4
Gee, I must be doing something all wrong. Even with a battery I was unable to get rid of the hum. The hum was there if I used a regulated supply or battery. There is a chance I may be hearing more noise because my speakers are in excess of 100db 1w 1m.
Even with over 100,000 mfd of cap I still had hum so I gave up on it.
Old 2nd February 2006, 10:46 PM   #5
http://home.pacifier.com/~gpimm/battery%20charger.gif
This is an example of someone elses need for the battery charger and battery setup when trying to tame the #26 hum problem.
Old 2nd February 2006, 10:48 PM   #6
http://vinyl.and.triodes.net/diy/26_preamp/26pre.htm
And this
Old 3rd February 2006, 11:11 AM   #7
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Whoa are you into horns? I like them, if only I could afford some...
Old 3rd February 2006, 11:14 AM   #8
My speakers are 3 way and have horn HF and Mid.
Old 4th February 2006, 12:05 AM   #9
kevinkr's Avatar
My speaker system is the old JBL Rhodes C37 cabinet with 075 horn tweeter and D130 15" woofer. The Rhodes cabinet is a reflex design, overall efficiency is well over 100dB, no audible hum from the pre-amp with my 300B se amplifier which has around 22dB of gain.
You can definitely get quiet out of a 26, putting an electrostatic shield around it may help.. You can make one to try out of tin foil.. LOL
edit: fix my usual stupid typos
www.kta-hifi.net
Old 4th February 2006, 01:50 AM   #10
Kevin,
Do I have to use the UTC HA 133 transformers or can I use a choke or plate resistor? The reason is that I am finding the HA133 is very hard to come by.
Aikido tube choice peterr Tubes / Valves 25 12th July 2009 06:46 PM
Aikido linestage tube choice? (again) Jolojl Tubes / Valves 2 29th November 2007 11:12 AM
Aikido 24V tube linestage Sarchi Swap Meet 2 11th October 2007 10:12 PM
tube hum in Aikido cbutterworth Tubes / Valves 3 8th March 2007 05:45 PM
Aikido tube heater floating Craig405 Tubes / Valves 6 27th March 2006 02:38 AM
Page generated in 0.09774 seconds (83.96% PHP - 16.04% MySQL) with 10 queries
