diyAudio Sponsor
Old 30th January 2006, 03:00 PM   #1
Default look what I found this weekend!
I was cleaning out some of my grandfathers stuff this weekend and found about ten boxes of tubes! Lots of different stuff. 12ax7 12au7 6l6 813 are the only ones I can remember off hand. A few cool looking tubes with mercury in them. I am not sure what they are. Rectifiers? Then I found some really big ones. Three 4 1000a's a 4 400a and four 4 250a. Anyway I have always wanted to build a tube amp. So no I have no reason not to Here is a pic. from one box.
Old 30th January 2006, 04:18 PM   #2
6h5c is offline 6h5c  Netherlands
One Seriously Addicted to Audio and Electronics
6h5c's Avatar
You are a lucky ****!
I'm jealous This is like finding a treasure with an old map
The ones with mercury are most likely rectifiers. Be careful with them, both mechanically and electrically!
Ray.
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 30th January 2006, 04:35 PM   #3
Congratulations with your find
Mercury rectifiers, I think I read some place the they should be kept vertical for a couple of days before applying voltage to them..not sure why, maybe the mercury in the wrong place could make a short between anode and cathode?
Anyone, please straight me out here.
Note to myself: Never again use fingers to check if there still is voltage left in a capacitor...
Old 30th January 2006, 07:52 PM   #4
i_should_coco's Avatar
Sort of - they need to be run on filaments only for a while (the interval varies from data-sheet to data-sheet). I reckon 15 mins to 1/2 hour should be fine. And yes, it is to make sure that there are no blobs of mercury to cause a short.
Pete
Old 30th January 2006, 07:58 PM   #5
beamnet is offline beamnet  Netherlands
beamnet's Avatar
Send a message via MSN to beamnet
You could select a few tubes to make an amp, sell the rest to us for cheap and use the money to buy transformers and stuff!
Bas
Old 30th January 2006, 08:12 PM   #6
poobah is offline poobah  United States
poobah's Avatar
That's very nice... now, I hate you.
Old 30th January 2006, 09:01 PM   #7
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Cool!
Post a list of all the tubes here and someone will be able to tell you what to build
Old 30th January 2006, 09:17 PM   #8
poobah's Avatar
All of those tubes are very hazardous to the environment... send them to me and I will take care of them for you...
Old 30th January 2006, 09:39 PM   #9
I'll go one better than Rob. I'll pay postage and give you a few dollars to boot.
Old 30th January 2006, 09:52 PM   #10
poobah's Avatar
You're a dog Joe... I like dogs... but, you're still a dog!
Wierd Projects for the Weekend !!!!! poynton Everything Else 9 5th February 2007 02:46 AM
L.A. VTV Audio Expo this weekend Apex Jr Everything Else 1 31st May 2006 03:40 PM
VTV Expo this weekend in New Jersey timothy Everything Else 0 4th May 2006 09:07 PM
Nothing to do this weekend?...here is a toy for you, have fun! destroyer X Solid State 13 30th January 2006 11:14 AM
Page generated in 0.10178 seconds (80.12% PHP - 19.88% MySQL) with 11 queries
