Look what I found this weekend! - Page 3 - diyAudio
Old 31st January 2006, 02:52 AM   #21
rdf is offline rdf  Canada
rdf's Avatar
Originally posted by beamnet
and exactly WHAT iron are you going to use?
the biggest opt is the hammond 275 watt opt
Jeez, so don't run all 3000 volts!
Old 31st January 2006, 02:58 AM   #22
Tubelab_com's Avatar
Actually they are not as bright as an 833A, they just pump out more heat.
The 4-250 and the 4-400 are very similar, the 4-400 has radiator fins on the plate, so it can dissipate more power. They are both tetrodes. The screen grid voltage is 800 volts max, which would allow triode connection at low (800 volts) voltages.
Operation as a tetrode can lead to nonlinearities, but it is also possible. Neither of these conditions is optimum for a good audio amp.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 31st January 2006, 03:20 AM   #23
Send a message via AIM to DigitalJunkie
You might be able to get away with fewer of the Hammond trannies than you'd think.
http://www.dogstar.dantimax.dk/tubestuf/dzindex.htm
"I found that the doubled-up output transformers really isn't necessary. Dogzilla works just fine with "just" a single Hammond 1650R. Just goes to show how conservatively rated these things are; I'm still getting well in excess of 200 watts out of a single transformer rated at 100 watts (albeit for hi-fi use), with no sign of overheating."
Granted that is for Guitar amp duty,but even in HiFi applications you can "push" them a fair bit.
Old 31st January 2006, 09:32 AM   #24
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Well for a nice simple amp, how about a single-ended 6L6 with 12SN7 for a driver?
That would sound good, and be very easy to make.
Old 31st January 2006, 06:19 PM   #25
Sounds like a good place to start. I still have a bunch of boxes to sort. Looks like my project backlog just got bigger Now off to search... Thanks.
Wierd Projects for the Weekend !!!!! poynton Everything Else 9 5th February 2007 03:46 AM
L.A. VTV Audio Expo this weekend Apex Jr Everything Else 1 31st May 2006 04:40 PM
VTV Expo this weekend in New Jersey timothy Everything Else 0 4th May 2006 10:07 PM
Nothing to do this weekend?...here is a toy for you, have fun! destroyer X Solid State 13 30th January 2006 12:14 PM
Copyright 1999-2017 diyAudio
