| diyAudio Sponsor | ||
#11 |
C-J,
That you have some budget flexibility is a good thing. "El Cheapo" can serve as food for thought. Better O/P "iron" allows you to do MORE. However, the 12AT7/ECC81 differential phase splitter will serve you WELL in a more powerful circuit. Push/pull O/P topology cancels internally generated even order harmonic distortion. When a PP distortion spectrum of odd harmonics is combined with the spectrum of the 'T7, the result is a PLEASING 2nd>3rd>4th ... 2 stage monoblocks of 'T7 splitter drivers and EL34 "finals" need to be combined with a line stage that has a little gain. That fits well with your stated objective.
Eli D. |
#12 | |
Is that the best sounding driver tube you've tried in your own PP amps? What else have you sampled?? Always pleased to hear the results of others' experiments!
check out my avitar and go easy on me ok? :-) |
#13 |
If I was going to build an amp and had to source everything, I'd look at El Cheapo too. See Eli's link above.
Eli's design seems to make a lot of sense, fairly simple but still should sound great. What I really like is most of the parts can be sourced from Jim "Mr. Citation" McShane. My guess Jim isn't making a dime on this but just wants to help us DIY tube guys. Remaining parts can be sourced from vendors listed on the thread. I'm currently working on a couple 6v6 amps and have another Dynaco Mark III in queue otherwise I'd build this one. rick |
| how to select an ntc thermistor? | jarthel | Parts | 7 | 2nd April 2007 11:00 PM |
| Help to select the design | denbo123 | Multi-Way | 6 | 30th June 2006 11:06 AM |
| Please help me select a FR design... | Christof | Full Range | 0 | 1st March 2005 10:54 PM |
| Page generated in 0.22455 seconds (27.71% PHP - 72.29% MySQL) with 11 queries |
