diyAudio Sponsor
Old 28th January 2006, 12:40 AM   #1
Default Help selecting a DIY schematic
Hello All...
I have recently gotten into DIY tubes, working on some older EICO gear. I have to admit, I am not an expert by no means. I have a vintage HH Scott LK72 (kit) integrated - and was interested in using the iron off it to do another DIY integrated amp with.
The amp has 1 power tranny and 2 output trannys. I am not sure where to look to get the specs for these, as I am sure their specs will determine the tubes it can drive. It is rated @ 35wpc.
I would like like recommendations on some published schematics to build a integrated on a new chassis - like the Hammond chassis'. I am very interested in using the 6sn7 preamp tubes - like was used in some of the Williamson amps. I am not sure what power-tubes are candidates for the iron I have. Any help on tracking down the specs for the trannys I have (power + output) would be very greatful. I would like something rather simple, as I am rather new at this. I do not need a phono-section - if that helps narrow it down any.
I am open to any suggestions - I am jus not sure what this iron is best suited to drive that is rather simple to build with tubes that are relatively easy to roll.
Any is help is greaty accepted.
Nate
Old 28th January 2006, 03:10 AM   #2
tubelab.com's Avatar
If I remember correctly the LH72 used EL-34's it was a pretty good amp, and might be worth rebuilding if it is in good shape. If you are determined to use the iron to build your own, there are zillions of EL-34 schematics on the net that make about 35 watts per channel. Pick one that fits your needs that uses parts or tubes that you have, or want to use.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 28th January 2006, 03:33 AM   #3
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
Default Re: Help selecting a DIY schematic
There are atleast a few ckts using 6SL7 and 6SN7 out there on the net.
Steve Bench has a triode 6SL7-EL34 ckt on his website, Wayne has posted a ckt that uses a 6SL7 and 2 6SN7 for stereo EL34 amp, Raymoth and Sy have posted full diffrential ckts that use 2 6SL7 and 2 SN7 per stereo amp.
see this thread. it might help...
EL34 schematic confusion
...still looking for the holy grail.
Old 28th January 2006, 03:49 AM   #4
These are the tubes the LK72 use:
(4) 12AX7
(2) 7199
(Split-load phase inverter)
(4) 7591
(1)5AR4/GZ34
Nate
Old 28th January 2006, 04:00 AM   #5
Scott LK72B schematic here. The LK72B uses 7591s as the "finals". IMO, there are no good reasons for using the O/P "iron" with any other type.
Scott, like Fisher, used a discrete winding for a negative supply that biases the "finals" and powers 12AX7 heaters. The bridge rectified supply in the LK72B is approx. 50 V. If you use a voltage doubler instead of a bridge, there are plenty of Volts available for series regulated bias and CCSes in the tails of differential phase splitters.
Take a look at dhaen's PP 7591 thread. A fair amount of that project is relevant, although the Scott power trafo will have to be paired with a cap. I/P PSU filter. There are all sorts of nice 12AT7s that can be "rolled".
Eli D.
Help selecting a DIY amp for... BlizzofOZ Chip Amps 1 30th April 2009 09:38 PM
Help selecting DIY amp for... BlizzofOZ Class D 2 29th April 2009 03:03 PM
Need help selecting DAC chip roee Digital Source 1 26th April 2004 04:55 PM
Help selecting an amp FBLEAGH Solid State 1 21st September 2001 05:00 PM
Page generated in 0.08746 seconds (74.73% PHP - 25.27% MySQL) with 10 queries
