| diyAudio Sponsor | ||
#101 |
frugal-phile(tm)
I have the boards in hand... after i'm back from the Easter away trip i'll start distributing boards.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#102 |
Banned
#103 | |
Can I use the CCS with MJE340 with a 6B4G? How?
Regards Åke |
#104 |
Quote
I have the boards in hand... after i'm back from the Easter away trip i'll start distributing boards. dave What is the cost of the boards plus shipping to the US? |
#105 | |
If you mean could you use the MJE340 variant in the cathode circuit of a 6B4G, then yes.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#106 | |
Regards Åke |
#107 | |
frugal-phile(tm)
The 1st batch will be $8/board (we are paying the tooling charge, which -- as long as the design doesn't change -- will mean that the cost for the next run could be quite a bit less -- and the order was "small"). This includes a $1 donation to diyAudio/board. Post to the US (up to 10 boards) is $6 Air/$4.50 surface. All other contries but Canada $7.50 Air/$5.50 surface. Canada is more complex. I can also send a few boards by letter post, but it doesn't get insured so i'd rather not do it that way. dave
#108 |
So how is progress?
Did the boards survive the pacific flight.... I ordered the minimum 5 set of board's, when do I pay 5 x $8 + freight too whom knut
If it's stuck, force it... If it breaks, what the hell, it needed replacement anyways.... Amateurs fixing a fault: they succeed but then discover another fault in addition to the part they just broke.... |
#109 |
frugal-phile(tm)
The big group buy is still a ways off... if you want some of the 1st round of boards mail me directly please (those are the $8 ones).
Anyone in the Wiki, i am assumming are waiting for the big batch. dave
#110 |
hi dave,
did mine came with instructions? for a newbie? |
| Another CCS for tubes/valves: PCBs | Doc B. | Tubes / Valves | 77 | 23rd January 2008 08:10 AM |
| Valves-tubes-mosfets- | Graeme | Tubes / Valves | 0 | 21st February 2002 04:47 AM |
| Page generated in 0.10934 seconds (80.33% PHP - 19.67% MySQL) with 11 queries |
