diyAudio Sponsor
Old 26th January 2006, 11:53 PM   #1
nkko is offline nkko  Alderney
Default DIY something like iMPAMP??
Does anyone know where i can found similar DIY project with complete schematic to build?
Thanks for any help!!!
Old 27th January 2006, 09:42 AM   #2
sorry here is a link impamp
and can someone suggest me a pair of good speakers thet would play nice with that kind of amp.
i need it mainly for my ipod and laptop pc.
Old 27th January 2006, 09:50 AM   #3
pinkmouse's Avatar
That is so sweet!
I would go for something like the new Jordan JXR6 drivers to match that.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 27th January 2006, 10:48 PM   #4
andrei is offline andrei  Canada
I designed a small 6SN7-6BX7 push-pull amp using commodity parts - see schematics. Three tubes, single PCB construction, solid state HT rectifier, toroidal output transformers. Not as compact as iMPAMP, but a little bit beefier at 5W/channel.
Old 27th January 2006, 10:53 PM   #5
PCBs are already laid out and manufactured - they are 4x5.5 inches, double side, solder mask over silver-plated copper. I just need build a prototype and test it .
Old 28th January 2006, 01:39 AM   #6
I've taken a look at the iMPAMP web page - it's a cute design. Here is my reverse-engineering summary:
Amplifier topology is a single stage push-pull using 6021W sub-mini tube. That tube has 0.7W anode dissipation rating, which means that it runs in Class B to get 1W output. Bias for PP pair is done with a single blue LED. External 12V/1A PSU feeds two 6021 heaters in series, and HT is stepped up inside by a pair of AMVECO 70000K 1.6W toroids connected in reverse. Rectifier is obviously solid state. The only thing which is not quite clear is how phase splitting is done in a front-end...
Old 28th January 2006, 02:34 AM   #7
Cool amp!
Fostex FE207E has a high sensitivity, 95db/W you`ll need it with just a one watt amp.
5902 subminiature pentode has a max anode dissipation of 4W, could make a cool little single ended 1W spud-amp...
Oh no, I got a couple of them in my drawer, juuuuust what I needed now, another project...
Peter
Old 28th January 2006, 02:55 AM   #8
http://www.roehrentechnik.de/html/kolibri.html
http://www.jogis-roehrenbude.de/Lese...rmann-Mini.htm
Old 28th January 2006, 03:16 AM   #9
http://mapage.noos.fr/dom.mafrand/schematics.htm
http://amps.zugster.net/projects/sub...e/gallery.html
Old 11th March 2006, 03:22 AM   #10
userguide's Avatar
Andrei,
You're right !
Here what I found to complete the reverse-engineering of the ImpAmp:
Two OP275 phase-splitter like this circuit (see pic)
(Personnaly I prefered the DRV134 for phase splitting)
Transformer: Fender W022913 (125A10B)
PART# 022913
MOUNTING 2 13/16"
HEIGHT 2"
LENGTH 2 5/16"
WIDTH 2"
WATTS 12
PRIMARY 8500 CT
SEC 8
So nothing missing to build a ImpAmp clone !?
Let's build the YinYamp !
What do you think about my design (based on IMPAMP) jtrujillo Tubes / Valves 5 29th June 2006 10:50 PM
Page generated in 0.09902 seconds (78.54% PHP - 21.46% MySQL) with 11 queries
