Any opinion about these transformers:http://www.edcorusa.com/classx/tube_...xse15-8-5K.htm I am looking for the cheapest output transformers and these looked quite good. Itīs for a first time project and am like others,donīt want to spend fortunes for a first try. Thank you |
#2 | |
http://triodeelectronics.com/tfchxfwi48oh.html but they are only 100Hz-20kHz and 5W. At that price you would even have to look hard on eBay to find a cheap vintage transformer pulled out of a console that costs less.
[Canadians] better hope the United States does not roll over one night and crush them. They are lucky we allow them to exist on the same continent. Ann Coulter |
#3 |
#4 |
Crusher
Wow. That's really cheap. Any idea what the maximum DC current is?
#5 |
Contributing
The Galaxy boxes on that site look pretty good too.. Not sure about that output transformer, no specs.. LOL
Ciao...
www.kta-hifi.net |
#6 |
The transformers are not good for the proper tube single ended
design... datas, like usual common rule, are without crutial units of the device, like primary inductance capacitances, leakage inductances wire diameters gap lenght... we have only, like in most cases, impedance ratios that means nothing (but most designers do not write those values at schematic diagrams, why should manufacturers do so ?..) Anyway the transformer and simillar models can be with great succes implemented in guitar amplifiers and old tube radios...
#7 | |
However, the original post clearly stated this was about building a first tube amp and trying to keep budget down. In that context I believe these transformers are an excellent choice.
#8 |
I can't speak for the Edcor transformers, since I had never heard of them until now. I will order a pair and subject them to my usual torture testing.
I have tested the Triode Electronics units that were mentioned. I was amazed that some decent sound could come out of such a tiny transformer. The Triode unit is specced for 40 mA max, I had no problems running 60 mA with a 300B. The sound was clean and I did not notice any transformer saturation with real music playing through speakers at about 3 watt peaks. It helps that my speakers have an impedance bump at the frequency that saturation should start (70Hz). Many of the listeners could not always tell which had better sound, the Triode unit or a Hammond 125CSE. It was easy to pick out the One Electrons though. The Edcor units are twice as big for only a few dollars more. I hope they work twice as good.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#9 |
Hmmm...I'm thinking the 60 watt 6600/4 ohm PP transformers from Edcor might work well for an 845 PP into 8 ohm speakers???????
#10 |
I don't know if the PP transformers can take the voltage of the 845. I don't know where you intend to operate them.
I just ordered a pair of the cheap ones (XSE15-8-5K). The sales girl said their transformers were not stocked, and are built to order. She said that mine would go out next week. I will subject them to listening tests and frequency response tests with a few different tubes when I get them. I will report the results here. If I like them, then I may try some of their other transformers. They have some line to voice coil, and amplifier to line transformers made for sound distribution with acceptable frequency response that are reasonably priced. I am thinking PSE 6336's or PPPSE 6AS7's ( I don't have any 6C33) driving a 140 volt to 8 ohm transformer.
| Thread Tools | |
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 05:10 PM |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 10:44 AM |
| Ultra Cheap transformers? | audio_moksha | Tubes / Valves | 8 | 8th March 2008 08:53 PM |
| Where to get Cheap Transformers? | lgreen | Parts | 5 | 23rd July 2003 05:34 PM |
| Page generated in 0.10537601 seconds (100.00% PHP - 0% MySQL) with 11 queries |
