| diyAudio Sponsor | ||
#11 |
Dang !!!
If these guys make a decent xfrmr, they will be the diyer's new best friend. I looked around the site and found they offer interstage, SE, PP, ribbon mic, and attenuater Xfrmrs...all VERY resonably priced. And if that isn't enough, they offer a custom service with no setup fee, and no minimum order, Did I say Dang !!!
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again. |
#12 | |
RIP
I vascillate between the current low voltage "fad" of around 450VDC and a more respectable 750VDC. Anything over that becomes too expensive for components that are reasonably spec'ed for safety.FWIW, I've tried the Edcor 10k:600 transformers(their cheapest version), and they pale in comparison to similarly priced power toroids...although a number of people have given positive reviews of them. |
#13 |
There is a comparison between an Edcor and a Hammond 3.4K PP transformer.
Looks promising. The Edcor site does not list the net weight of the transformers though.. http://www.angelfire.com/electronic/...oblock_UL.html |
#14 |
I think I'll buy a couple of the 8000 ohm jobs to hook up to my (borrowed from a sears console) el84 se el cheapo amp. Theyr'e only $15.?? each. Anything would be much better than the ones that it has.
steve |
#15 |
I wouldn't be surprised if the 25W SE for $27 were the hot ticket for an EL84SE amp on a budget. They should get lower than 70Hz if just an EL84 is driving them.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#16 |
Thank you everyone for your posts!Can´t wait for TUBELAB´s test results....
cheers to all. |
#17 |
or you could try:
http://www.welter-electronic.de/baut...ebertrager.htm select Standard, scroll down, the Ü/ET-2 might be the one if you look for a cheap opt. btw. their HE-ET 30 (look under High End) is not bad, and the price is very good! regards Michael |
#18 |
I got my pair of XSE15-8-5K today. Unit construction is great.
On a 3 watt 6EW7 amplifier, we're talking 19Hz >>20KHz (sig gen doesn't go higher) with 5dB NFB and 25Hz >>20KHz with zero NFB. Nothing wrong with this tranny for SE. |
#19 | |
These are good numbers for a $18 transformer. I want mine, NOW!
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#20 | |
diyAudio Moderator Emeritus
Thanks. |
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 06:10 PM |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 11:44 AM |
| Ultra Cheap transformers? | audio_moksha | Tubes / Valves | 8 | 8th March 2008 09:53 PM |
| Where to get Cheap Transformers? | lgreen | Parts | 5 | 23rd July 2003 06:34 PM |
| Page generated in 0.09559 seconds (87.00% PHP - 13.00% MySQL) with 11 queries |
