EL84 Amp - Baby Huey - Page 92 - diyAudio
Old 28th November 2010, 07:08 PM   #911
Brouilly's Avatar
In the first time baby huey thread, gingertube says connect a 10ohm resistor from a 12v supply to the positive bias side, to check the circuit. You should read 0.4v across the resistor for 40mA current.
I am testing my circuit using the CCS winding (5v 3A) and a 470ohm resistor.
I read 5.28v across the resistor, ohms law tells me that's about 11mA current.
All 4 of my bias circuits read the same, so unless ive built all 4 wrong... I must be doing something else wrong...?
Can anyone help?
Charlie
Still learning
Old 28th November 2010, 07:36 PM   #912
Soonerorlater's Avatar
Apologies in advance for stating the obvious, but you need dc and it may be unreliable to use less than 12v
Bill
Old 28th November 2010, 07:41 PM   #913
Brouilly's Avatar
Ah.. yes.... that would be it then.
Think ill put this to bed for today and have a glass of wine
Old 28th November 2010, 07:44 PM   #914
My trouble is after the third glass I feel like going back to work
Old 28th November 2010, 08:03 PM   #915
Brouilly's Avatar
I just quickly checked with a 9v battery, read about 15mA.
Should I just continue with the build and check again when everything is in place? As I dont have a workshop power supply to get the 12v DC
Charlie
Old 28th November 2010, 08:10 PM   #916
I used the -dc output from the voltage doubler needed for the ccs, it was about -13vdc IIRC.
ps how many glasses did you have..
Old 28th November 2010, 08:14 PM   #917
Brouilly's Avatar
its a very nice Rioja....
Old 28th November 2010, 08:18 PM   #918
The last time I had a bottle of red I went on diyaudio and got myself "moderated"
They're very understanding here
Old 28th November 2010, 09:00 PM   #919
Brouilly's Avatar
OK..
10.4V across 470ohm, 22mA..... getting closer
Old 28th November 2010, 09:10 PM   #920
Brouilly's Avatar
So that's with a 12v supply..
why I am getting half the current I should have? ..any more school boy mistakes I might of made?
Red Light District/Baby Huey (EL84 P-P) Output Iron dsavitsk Tubes / Valves 3 14th February 2009 01:21 AM
Copyright 1999-2017 diyAudio
