EL84 Amp - Baby Huey
Old 29th January 2006, 09:51 PM   #31
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Thank you so much Ian. So I think I have to tweak it a little bit to adapt the operating point to my specific B+
Old 29th January 2006, 10:30 PM   #32
ilimzn is offline ilimzn  Croatia
Originally posted by SY
Actually, my question was about using pentodes for the input tubes, since the desiradata there are high plate resistance and high mu. Seemingly, they would work better than triodes for this application.
Definitely agreed, even though pentodes are not 'en vogue'
The EF86 is an obvious choice... though it would be intereesting to dabble with the less glorious EF80, EF184...
Old 29th January 2006, 10:58 PM   #33
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
It is actually very simple, and elegant - and once you have figured it out, like most elegant designs, obvious
thanks, very informative for a noob like me.
how about the 6ba6/EF93 pentodes? i still have a bunch of them.
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 1st February 2006, 11:53 AM   #34
pengboon is offline pengboon  Singapore
Default Ultralinear at which %?
for EL84 PP, what kind of UL tapping is nice in this case? Lundahl gives 33%, Hammond gives 40%... Yet some use 43%
thx!
Old 1st February 2006, 11:56 AM   #35
Giaime's Avatar
There's a precise relation between output power and distortion and the ratio of the UL tap. A relationship that I can't remember at the moment
Old 1st February 2006, 12:04 PM   #36
On Hiatus
SY's Avatar
Here's an imprecise relation, swiped right off the Mullard datasheet for EL84- 30% tap gives more power, 43% tap gives lower distortion.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 1st February 2006, 12:38 PM   #37
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
I think you mean 20%.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 1st February 2006, 12:48 PM   #38
On Hiatus
SY's Avatar
I need to drink more coffee.
Yes, 20% maximizes power.
Old 1st February 2006, 03:11 PM   #39
Giaime's Avatar
Coffee is bad Stuart, it hurts. Better drink more wine
Old 1st February 2006, 03:48 PM   #40
You know, I have a couple pairs of those odd PFL200 signal/power dual pentodes with a decal socket, and the more I look at them, and this thread, the more I keep thinking: lower B+, lower power, perhaps about 4W max, pentode operation... who knows
EL84 Amp - Baby HueyHide this!Advertise here!
Red Light District/Baby Huey (EL84 P-P) Output Iron dsavitsk Tubes / Valves 3 14th February 2009 01:21 AM
