Old 9th November 2006, 11:35 PM   #211
LowRedMoon's Avatar
Thanks, Ian.
What has been your verdict on the bypass cap configuration?
Old 10th November 2006, 01:29 AM   #212
Adam,
See earlier post. I'm using a single 1000uF/25V Blackgate NX across each EL84 Cathode current source. This is the best I've been able to come up with.
Ian
Old 10th November 2006, 06:33 AM   #213
frugal-phile(tm)
planet10's Avatar
Originally posted by LowRedMoon
As preamps go, I think the Bottlehead (Extended) Foreplay would be a good bet for around $400, but I don't like the fact that I'm not forced to learn things in order to build it - the amp is already planned and laid out. That idea really turns me off. I've always been one for steep learning curves and the associated satisfaction that follows earned success. Yeah. I have problems.
Have a look at the 12B4 preamp threads.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th November 2006, 02:55 PM   #214
LowRedMoon's Avatar
I've been sourcing power transformers for mono versions of this amp.
Here's what I've found to be adequate. Please tell me if there are any known disadvantages to using smaller transformers instead of one large one.
Plate and heaters:
Hammond 261G6 250V CT @ 130ma, 6.3V @ 2A
CCS 5V:
Hammond 167M5 5V CT @ 3A (higher current ratings available) ...and I honestly don't know what to do with the centre tap.
Old 11th November 2006, 03:04 PM   #215
LowRedMoon's Avatar
dave
Thanks, Dave. I'll check it out. Would it be this thread you are refering to?
Yet another 12B4 line stage...
Old 12th November 2006, 05:32 AM   #216
frugal-phile(tm)
planet10's Avatar
That is one of them... it will have the info you need.
dave
Old 7th December 2006, 07:03 AM   #217
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
hi Gingertube,
I have made a world audio kit kel34 and it sucked. Anyway, Ive never heard another valve amp so I want to build good one to decide if I like valve amps or not.
Thing is I cant find any where in NZ or Aussie where I can find good quality transformers. Do you have any suggestions where I can find good transformers?
Old 7th December 2006, 08:38 AM   #218
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
I've never seen one in the flesh, but that's odd since it's a derivative of the classic Mullard 5-20. Are you certain everything is correct? Are the DC voltages as specified?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 7th December 2006, 08:50 AM   #219
yes everything was correct, it really was mediocre.
Old 7th December 2006, 09:00 AM   #220
EC8010's Avatar
That's a shame. Treat it as a test bed for other circuits?
Red Light District/Baby Huey (EL84 P-P) Output Iron dsavitsk Tubes / Valves 3 14th February 2009 01:21 AM
Copyright ©1999-2013 diyAudio
