EL84 Amp - Baby Huey
Old 13th April 2018, 02:47 PM   #2031
e_fortier is offline e_fortier  Canada
e_fortier's Avatar
Your feedback terminal is not connected to anything.
Apply your feedback.
Old 13th April 2018, 03:14 PM   #2032
jcastellano is offline jcastellano  Spain
Ok.
From speaker output plus to terminal right or left? Or is one side of this terminal tied to ground?
Jorge
Old 13th April 2018, 10:57 PM   #2033
Default Hum
After a successful test, I installed the amp in the main system, with 92dB speakers, but the hum is quite noticeable. I tried to lower the gain with the input pots but it isn’t sufficient. I have connected the ground to only one point and I tried also to no connecting it at all. In both cases behave the same way.
The amp now is very tidy with al cables routed. See photos.
Any clue?
Jorge
File Type: jpg E254590C-C325-4567-8EC9-178790AE0311.jpg (998.9 KB, 185 views)
File Type: jpg B04DBAE2-DD54-4717-B0E4-D8D835615E91.jpg (994.4 KB, 182 views)
Last edited by jcastellano; 13th April 2018 at 10:59 PM. Reason: Photos not loaded correctly
Old 14th April 2018, 12:45 AM   #2034
anatech is offline anatech  Canada
anatech's Avatar
You do know that your circuit is really close to the transformers - right? Does the hum level drop if you move the PCBs away from the transformers? The power transformer at the very least.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 14th April 2018, 06:02 AM   #2035
vgeorge is online now vgeorge  Greece
vgeorge's Avatar
You could also try to use a coaxial cable for the input signal.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 14th April 2018, 01:13 PM   #2036
Thumbs up Ok. I will try
-Chris
Hi Chris,
Thanks for your input. I’m waiting for a new power supply for the heaters, this will give some real estate to move down the amp boards because the little dc-dc power supplies at the bottom will be taken out. As soon as it arrives from France I will install it and make the movements required.
Jorge
Old 19th April 2018, 05:44 PM   #2037
mctavish is offline mctavish  Austria
Progress! Should be finished by the weekend and then the testing phase...
But I am optimistic!
Outputs are from an AA-100 heathkit, ~7k to 4-8-16 ohm
Power trans are from Sony reel to reel , good quality shielded.
Two Hammond chokes and off we go!
EL84 Amp - Baby HueyHide this!Advertise here!
Red Light District/Baby Huey (EL84 P-P) Output Iron dsavitsk Tubes / Valves 3 14th February 2009 01:21 AM
