EL84 Amp - Baby Huey
Old 2nd February 2018, 01:06 PM   #1921
ckwong99 is offline ckwong99  Hong Kong
Thx Bandol it is optional unless the amp osillation ?
Old 2nd February 2018, 02:15 PM   #1922
bandol83 is offline bandol83  France
@mctavish
I prefer option 2, more classical for tube amplifier, but for all of the 3 options I would have put the capacitors in the back between the power transformer !
Marc
Old 2nd February 2018, 02:26 PM   #1923
@ ckwong99
Yes because the Baby Huey amplifier use a special shunt feedback architecture with R13, which in combinaison of the feedback of the UL taps on the output tubes screen grid will be enough to get a stable amplifier without global feedback ! In fact this is an advantage of this amplifier because many Audiophiles didn't like global feedback
However if you build a pentode output version with the screen grid connected to a fixed regulated power supply, you may need to add the global feedback...
Marc
Old 2nd February 2018, 04:06 PM   #1924
mctavish is offline mctavish  Austria
As they are film caps I was trying to keep them as close as possible to the board to reduce inductance in the leads (and thus defeat the purpose of a large film cap connected directly to the C.T. of the output transformer).
I am still working on the layout.... no metal chips yet...
Old 9th February 2018, 02:30 AM   #1925
e_fortier is offline e_fortier  Canada
e_fortier's Avatar
Very interesting thread, subscribed
Old 27th February 2018, 01:21 AM   #1926
crispycircuit is offline crispycircuit  United States
Anybody have progress on the Bandol83 amp. I need ideas for the build?
The stuff you don't know always humbles us.........
Old 27th February 2018, 01:38 AM   #1927
SCD is offline SCD  Canada
Well I do not know if it is progress or not. But today I placed an order with Mouser. Last week I drilled the top plate of my chassis for the transformers and cut the wood for the base.
As seems to be the way with these things I am waiting for parts from all over the freaking world.
I think I will be able to start the real building in the next few weeks.
I hope this helps
I will likely start a build thread as this one is way to big and diverse
SCD
Old 27th February 2018, 01:50 AM   #1928
drpro is offline drpro  United States
Slowly gathering the parts. Got a MoFo and ASKA preamp in various build stages. The transformers are a big part of the cost on the BH for me. But moving forward once the other projects are completed.
Old 6th March 2018, 10:44 PM   #1929
e_fortier's Avatar
Some PCB + components for sale on the Swap/Meets section
Old 9th March 2018, 03:35 PM   #1930
e_fortier's Avatar
Hi
Looking for some recommendations on tube socket for the EL34 type
Looking for good quality stuff that makes good contact, I prefer the style can can be bolted to the chassis.
Are these good ?
6pc New 8pin Belton Style vacuum tube socket PCB mount valve For EL34 6550 KT88 | eBay
Also looking for some good one for the 12Ax7
Eric
EL84 Amp - Baby HueyHide this!Advertise here!
Red Light District/Baby Huey (EL84 P-P) Output Iron dsavitsk Tubes / Valves 3 14th February 2009 01:21 AM
