EL84 Amp - Baby Huey - Page 132 - diyAudio
Old 31st December 2012, 04:31 PM   #1311
Geosto is offline Geosto  Netherlands
Hi everyone
I like to share with you my creation of the Baby Huey.
This was made as part of the TubeSociety a course for building and designing valve amp's given by Menno vd Veen.
In this design i wanted to have some extra power there fore i put an extra set of EL84 tube's in the amp.
A part of this extra power is used to create some extra local feedback by increasing the resistor in the middle i have used 50K for this one.
http://www.diyaudio.com/forums/attac...1&d=1356974775
And this is how it looks like.
Regards George
Old 1st January 2013, 01:13 AM   #1312
Beautiful. Very nice.
I'm sure they sound as good as they look.
Scott
Old 1st January 2013, 01:17 AM   #1313
TheGimp is offline TheGimp  United States
TheGimp's Avatar
I like Black. Very nice.
Old 26th January 2013, 12:53 AM   #1314
Drewaudio's Avatar
Unhappy Strange PSU noise?!
Hi all,
I've been slowly building up my 6F6 version of the baby huey and today was the first time of fired up the PSU (no tubes or signal circuits connected). All voltages were as they should be but there was a strange buzzing noise coming from the circuit board. It sounded like a high voltage electrical discharge that varied as I changed the mains voltage with my variac....
The next hour or so was spend de-construction the PSU until I was left with only the basic HV diodes, subbers, CLC and bleed resistor...still the noise remained. Eventually I removed the 10nf snubbers that are across the HV diodes and hey presto problem fixed!
I've never come across this noise before and am at a loss as to what is happening. Can anyone help me understand what is happening with the snubbers? These are ceramic 10nf 3KV caps and the HV diodes are IXYS FRED 1200V 11A TO-220's.
Thanks in advance...
Old 26th January 2013, 01:21 AM   #1315
6L6 is offline 6L6  United States
6L6's Avatar
Don't damp (snub) a high-speed diode. They get cranky. You figured out the answer, however!
Old 26th January 2013, 01:39 AM   #1316
Drewaudio's Avatar
Thanks for the quick response! I wasn't aware that you shouldn't put snubbers across high speed diodes....you learn something new every day!
Old 27th January 2013, 02:39 PM   #1317
fmena is offline fmena  Canada
I'm yet another person (newbie) embarking on building a Baby Huey and have already ordered the output-transformers (MQ565) from Magnequest. These have the UL taps. I'm at the point of reading and re-reading many of the posts in this thread as for components needed
I wish to build the power supply seen on post #1287 and was wondering on the value of the choke. Am I correct in assuming that I could use the LL1673 (2.5 - 20 H) for this purpose?
http://www.lundahl.se/pdfs/datash/1673.pdf
If I correctly understand the choke pdf shown above, I can wire the choke to get different values. Would 5H be appropriate for this power supply in post #1287?
Cheers
Frank M
Old 27th January 2013, 03:41 PM   #1318
diyAudio Moderator Emeritus
Bas Horneman's Avatar
LL1673 is an excellent choice.
Old 27th January 2013, 03:56 PM   #1319
surfstu is offline surfstu  United Kingdom
will the choke make a noticeable difference? I'm planning on a similar supply for the early ecl86 baby huey design but the Lundahl chokes are near 150!
and why does no one use the GZ34 for rectification? I only ask because I already have the octal socket for it in my chassis....
Old 27th January 2013, 04:01 PM   #1320
GZ34 is as good a choice as any. Chokes can make a difference. But any will do. Minute differences. You'll only need one btw.
Red Light District/Baby Huey (EL84 P-P) Output Iron dsavitsk Tubes / Valves 3 14th February 2009 01:21 AM
Copyright 1999-2017 diyAudio
