EL84 Amp - Baby Huey
Old 8th December 2011, 03:09 PM   #1161
Brouilly is offline Brouilly  United Kingdom
Brouilly's Avatar
Thanks for the advice, I will do that.
I did just swap the el84s around and blew the power supply resistor, so I am sure now that my problem before was a faulty valve.
Cheers
Broke solderer with delusions of grandeur
Old 8th December 2011, 03:13 PM   #1162
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
If this was my amp I would like to know that all is well apart from the ECC803s ccs and the RLD bias scheme for the EL84's. I had similar problems with the ccs's in the basic BH version. I simplifyed the amp by replacing the preamp ccs with a 675R resistor ( IIRC ) and biased the EL84's separately with 270R resistors. Happily this gave me a working amp with all the proper voltage values. I then reintroduced the ccs's one by one solving any local faults as I went along.
Excellent advice.
If you can see the speaker cone move...it's not hifi.
Old 8th December 2011, 04:42 PM   #1163
Brouilly's Avatar
Agreed, thanks Bill.
It's great to come on this website and get some clarity when your mind is turning to mush.
Charlie
Old 8th December 2011, 05:43 PM   #1164
Soonerorlater is online now Soonerorlater  United Kingdom
Soonerorlater's Avatar
Aw shucks...........
Old 9th December 2011, 12:08 PM   #1165
Brouilly's Avatar
Originally Posted by Bas Horneman View Post
And did you check and double check the pinout?
1 and 8 (cathodes) to CCS
3 and 6 (anodes)
2 and 7 (grids)
With a fresh head and a new set of eyes I found my first wiring problem.
I don't know why I didnt check myself, because it did seem a different pinout to a normal ECC83.
JJ ECC803S / 12AX7
Should be 1 and 6 cathodes
3 and 8 anodes.
Pretty sure the ECC803s' ive been using will be damaged now, but they are easliy replaceable. I hope there is no other damage done.
At least we have progress!
Charlie
Old 9th December 2011, 12:30 PM   #1166
GloBug is offline GloBug  Canada
Banned
Right on.
Old 9th December 2011, 01:09 PM   #1167
3 and 8 anodes
I'll change the pinout on the schematic in the WIKI ASAP! Thanks for catching that.
[edit] Wait a minute. It should be 1 and 6 anodes. And 3 and 8 cathodes.
Old 9th December 2011, 01:14 PM   #1168
Nah they are tubes. Not transistors.
Old 9th December 2011, 01:23 PM   #1169
Brouilly's Avatar
Yes, sorry that's what I meant. Useless!
Old 9th December 2011, 01:44 PM   #1170
3 and 8 anodes.
1 and 6 anodes, 3 and 8 cathodes perhaps, .......
12AX7 and ecc803s and ecc83 all have the same pin-out.
In the wiki schematic it looks like top triode (a) has reversed cathode and anode pin numbers.
Sorry Bas, just spotted your edit......
EL84 Amp - Baby HueyHide this!Advertise here!
Red Light District/Baby Huey (EL84 P-P) Output Iron dsavitsk Tubes / Valves 3 14th February 2009 01:21 AM
