EL84 Amp - Baby Huey - Page 114 - diyAudio
Old 7th December 2011, 03:18 PM   #1131
GloBug is offline GloBug  Canada
Banned
I think if you had it on the neutral side, the current could bypass the fuse by going through ground.
I don't know for sure either, but logically you would want to limit the current entering the amp.
Old 7th December 2011, 03:20 PM   #1132
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Nah. The current can't hide . It has to pass from hot to cold.
planet10 needs your help:
Let's help Ruth and Dave
Old 7th December 2011, 03:27 PM   #1133
Banned
I respect your knowledge, but I'm telling you for safety sake the fuse needs to be on the hot side, the first thing connected should be the fuse.
If a properly functioning amp draws too much current, then yes a fuse would work on the neutral side.
Try it for your self. Put a fuse on the neutral, then ground the hot, you'll pop your 15A breaker, not your 1 amp fuse.
Old 7th December 2011, 03:53 PM   #1134
Ok. Put a fuse on hot. Then ground the neutral. Then the 15A breaker will pop also.
Since there is AC on the mains. I've never understood the difference between "hot" and "cold".
That was my point.
Old 7th December 2011, 04:06 PM   #1135
Brouilly's Avatar
It is an IEC socket with built in fuse.
I guess what I need to know is why the valves would instantly be drawing current. Before, there was about a 5-8 second warm up delay on the LED arrays, but then something changed and a screen resistor popped. And from then on, the LED array lit up straight away on power up.
Cheers
Broke solderer with delusions of grandeur
Old 7th December 2011, 04:10 PM   #1136
TheGimp is online now TheGimp  United States
TheGimp's Avatar
Pull both output tubes and see if it powers up and stays up. If so, try each output tube in each socket to see if it is the tube, or something else in the circuit. Possible shorted grid in the tube, either g1 or g2 (screen).
Proceed from there.
Old 7th December 2011, 04:24 PM   #1137
Brouilly's Avatar
OK will do. They are a brand new matched quad JJ EL84s so I hope that isnt the case.
Old 7th December 2011, 04:31 PM   #1138
Banned
That was my point.
Because "Hot" is the one carrying the A/C, not the neutral or ground. You can touch these if you want, not recommended.
Neutral is ground. (At the panel)
The current can exit on either one, the point being a fuse on the neutral will not protect from a short to ground.
Old 7th December 2011, 04:38 PM   #1139
Brouilly's Avatar
Wow. Do you have a fuse in your amp somewhere? Does that not blow first?
Can you suggest any reasons other than the shorted grids that this might be happening?
Old 7th December 2011, 04:56 PM   #1140
Banned
Post a good picture, maybe someone can spot something, never hurts to have a fresh set of eyes look at it.
Red Light District/Baby Huey (EL84 P-P) Output Iron dsavitsk Tubes / Valves 3 14th February 2009 01:21 AM
Copyright 1999-2017 diyAudio
