EL84 Amp - Baby Huey - Page 113 - diyAudio
Old 7th December 2011, 01:52 PM   #1121
Brouilly's Avatar
Just let the smoke out of a 150R 2W screen resistor, so that would mean the bias is drawing too much current?
Little bit worried about doing any damage to the output transformers, will they be ok as long as ive got the dummy load connected?
Broke solderer with delusions of grandeur
Old 7th December 2011, 01:56 PM   #1122
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Yes, sqrt (2W/150R) = 115mA screen current!
Short term this won't damage your opt, but if left running it would.
Old 7th December 2011, 02:13 PM   #1123
Brouilly's Avatar
I replaced it, and powered up again and it blew a second time. The LED array lit up straight away so there is obviously an issue. The array itself is fine, so what might be the causes of the sudden inrush of current?
Old 7th December 2011, 02:26 PM   #1124
TheGimp's Avatar
I"d check the grid resistor connections and and coupling caps to the output stage. Something has to be biasing it wrong to pull that much current. Also double check your OPT wiring.
If the LEDs light up, you know the cathode connection is there. You might measure the cathode voltage on power up to see if it reaches the expected bias voltage.
Old 7th December 2011, 02:38 PM   #1125
diyAudio Moderator Emeritus
Bas Horneman's Avatar
should 0v at ecc803 be grounded
The "bottom" of the CCS's of the driver/splitting stage should be wired to their respective "CCS power" connection. (Which are actually -12 to -13V or something like that).
The + part of the bias supply is connected to "ground". I.e. you should connect your CCS to a negative bias voltage.
If you can see the speaker cone move...it's not hifi.
Old 7th December 2011, 02:50 PM   #1126
Brouilly's Avatar
Thanks, I was initially just connecting the '0v at ecc803' to the '0v at ecc803' without grounding it also. At CCS power I was reading -13V but only reading about -0.5v at the cathode of the ecc803.
Ive replaced the resistor and powered up, and this time the dropping resistor in the power supply blew on the same channel. In rush of current again as the LEDs all lit up.
The wiring to the OPT is fine as is the grid connection and coupling cap. There's got to be something going on...
Old 7th December 2011, 02:54 PM   #1127
Wow. Do you have a fuse in your amp somewhere? Does that not blow first?
Old 7th December 2011, 02:55 PM   #1128
Brouilly's Avatar
1A time lag fuse on one half of the mains
Old 7th December 2011, 03:10 PM   #1129
GloBug is offline GloBug  Canada
Banned
Should be on the hot side of the mains?
Old 7th December 2011, 03:15 PM   #1130
I don't think it matters. Since the current is everywhere . Please correct me if I'm wrong.
Red Light District/Baby Huey (EL84 P-P) Output Iron dsavitsk Tubes / Valves 3 14th February 2009 01:21 AM
Copyright 1999-2017 diyAudio
