EL84 Amp - Baby Huey - Page 101 - diyAudio
Old 5th January 2011, 01:58 PM   #1001
Tyimo is offline Tyimo  Hungary
Default Power tansformer
Hi!
How big power transformer need for such an EL84 PP amplifier?
Is 100VA enough for two channels?
Tyimo
Old 5th January 2011, 09:15 PM   #1002
Nobody knows the VA rating of the power transformer for this amp????
Old 6th January 2011, 04:25 AM   #1003
boywonder's Avatar
My BH monoblocks are each powered by Hammond 270EX transformers 275-0-275 @ 125ma each; the Hammond website now rates the 270EX at 144ma or 118VA.
The EL84's need about 38ma each x 4, plus the phase splitter current, etc. so a stereo amp needs 175-200ma or so....more than 100VA
Old 6th January 2011, 11:26 AM   #1004
Thanks!
Old 24th February 2011, 05:00 PM   #1005
Brouilly's Avatar
I visited my old dear at the weekend and had a look at her BH.
Couple of points, the bias for the input stage seems to drift every time I visit. Reading the plates of the input valves it always drifts a few volts. What might be the reason for this? Or is that quite normal?
Also, a more generic question. The volume pot becomes noisy from 50%-99% turned, becoming more and more noisy. Then at its fully on position it is dead silent. Is this poor layout or wiring? Would a stepped attenuator be the answer?
The sound still amazes me, can't believe I gave it to her!
Cheers
Charlie
Old 24th February 2011, 05:30 PM   #1006
Miles Prower's Avatar
Yes, that's quite normal; I've seen the same thing in my own projects. As to what causes it, it's due to fluxuations in the AC mains voltage. The bias current of the finals drifts a few mA, depending on the time of day, and the overall load on the AC distribution system.
The sound still amazes me, can't believe I gave it to her! :headbash
It's dirt on the track and/or the thing is simply worn out. You might also want to take a look at the schemo to see if there is any DC flowing across the track and wiper. That'll cause a pot, especially a high resistance one, to go scratchy in no time.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 27th February 2011, 07:08 PM   #1007
Default Schematic for the latest version? & Parts list ?
Has Ginger settled on this version? A finalized schematic is would be great. This amp fits my requirments nicely.... Excellent project/thread... Thx
The stuff you don't know always humbles us.........
Old 28th February 2011, 11:18 AM   #1008
skippyboy's Avatar
+1 On that request
Old 28th February 2011, 11:21 AM   #1009
diyAudio Moderator Emeritus
Bas Horneman's Avatar
What version do you call "this version"?
Old 28th February 2011, 12:12 PM   #1010
There are "essentially" 2 versions.
From the Wiki page I've put up:
"AFAIK there are 2 major versions. The first (auto bias), which is probably the one newbies should build and a fixed bias version."
Baby Huey PP EL84 amplifier - diyAudio
I would suggest building the version in the Wiki (Which is AFAIK the latest auto bias version). And you can always try something you've lifted from this thread.
Red Light District/Baby Huey (EL84 P-P) Output Iron dsavitsk Tubes / Valves 3 14th February 2009 01:21 AM
Copyright 1999-2017 diyAudio
