diyAudio Sponsor
Old 24th January 2006, 08:30 PM   #1
leadbelly's Avatar
Default What do you guys use for HV toggles?
What do you guys use for toggle switches in HV applications, such as a pentode/triode strapping switch? I may be wrong, but this isn't a trivial application of a standard 250V switch and linearly derating for voltage. I have been burned in the past by what I assume is capacitive coupling through a submini switch and have seen plenty of surplus switches hade of ancient looking dielectrics I wouldn't trust for 400V. Am I wrong?
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 24th January 2006, 08:39 PM   #2
Sherman is offline Sherman  United States
I have put triode/pentode switches on a couple amps I've built and used regular mini or sub-mini toggles. I just don't switch it with power on. If you want to switch from triode to pentode while the amp is on you should use a switch rated for the voltage it will see.
--Sherman
Old 24th January 2006, 09:15 PM   #3
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Given that with a 400V HT, the audio could swing to almost +800V, you're right to be cautious. Whatever type of switch it is, it should have its body securely bonded to the chassis to prevent an internal arc from ending up on the toggle. I'm don't recall seeing any readily available switches that I'd trust. Hopefully, someone will come up with something...
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 24th January 2006, 10:25 PM   #4
SY's Avatar
This is why God invented relays.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 24th January 2006, 11:19 PM   #5
Tweeker is offline Tweeker  United States
Check local code before installing.
Be sure your foil hat has a good low impedance ground.
Old 24th January 2006, 11:24 PM   #6
leadbelly's Avatar
I'm sure it would work, but having to put on a suit every time I switched from triode to pentode or back is just too inconvenient...
Old 25th January 2006, 02:59 AM   #7
Majestic's Avatar
lol!
He has his other hand in his pocket at least...
check out my avitar and go easy on me ok? :-)
Old 25th January 2006, 03:06 AM   #8
anatech is offline anatech  Canada
anatech's Avatar
Hi SY,
You caught me off guard with that one! I needed a laugh! Thanks.
And yes, relays are a very good idea for this.
-Chris
Old 25th January 2006, 03:34 AM   #9
Dont know why Mr Crosley is so nervous, its just a filament generator.
Old 25th January 2006, 08:28 AM   #10
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
Default small togle switches
i use small ones and don't seem to be any problem, i can switch from triode to pentode mode on the fly!
this is my EL84 SET amp:
Guys Help tresch The Lounge 11 7th May 2009 05:05 PM
Hey, you guys! hairylee Introductions 1 19th November 2004 12:32 PM
Hi Guys! I'm one of the Portuguese Guys who love diy sapito Introductions 3 2nd September 2002 02:19 PM
Page generated in 0.09215 seconds (79.00% PHP - 21.00% MySQL) with 10 queries
