diyAudio Sponsor
Old 24th January 2006, 01:16 PM   #1
Tubesin is offline Tubesin  Macao
Default Static stain cleaning
Hello,
May you help me on how to clean the static stain on the aluminum face plate of the SP11 preamplifier? I tried with electronic solvent, W40 and carwax but only lighten up and cannot clean it completely.
Thanks your helping hands.
Attaching a photo
Old 24th January 2006, 05:16 PM   #2
kevinkr's Avatar
I would contact ARC directly and find out what the finish on the front panel actually is, and how to safely clean it. It is probable that there is a lacquer or some other type of finish on the aluminum, and it could even be that this has become discolored over time due to heat and air pollution..
Kevin
www.kta-hifi.net
Old 24th January 2006, 11:58 PM   #3
So... it might be the lacquer or the protection coating is oxidized then....
Stain on Baltic birch flaevor Multi-Way 10 12th November 2006 12:15 AM
Should I stain these veneer first? andy2 Multi-Way 5 16th January 2006 07:31 PM
stain for baltic birch ply? slappomatt Full Range 13 7th March 2005 09:17 AM
Black Stain for Oak cabinets? MCH Multi-Way 17 19th March 2003 07:16 AM
Page generated in 0.06979 seconds (68.42% PHP - 31.58% MySQL) with 11 queries
