diyAudio Sponsor
Old 23rd January 2006, 09:34 PM   #1
Default 60hl5?
Howdy, Anybody ever heard of this tube, 60HL5? I'm looking at an Arvin push-pull that uses em. I'm particularly wandering about a suitable cross as I can't find any at my normal tube gettin spots.Thank You kindley in advance.
"Make everything as simple as possible, but no simpler" Einstein
Old 24th January 2006, 01:16 PM   #2
Tom Bavis's Avatar
Can't find any info on that number. 60FX5 is the only 60V tube I've heard of - I think I have a few.
Old 24th January 2006, 02:29 PM   #3
60HL5 beam power amplifier, which can take 330V plate voltage, this tube has a high gm, very little info on search engines.
Old 24th January 2006, 04:23 PM   #4
smoking-amp's Avatar
Maybe the 6HL5 is related?
http://www.nj7p.org/Tube1.php?tube=6hl5
Ohms Law V = I R
Old 24th January 2006, 04:40 PM   #5
Tom Bavis's Avatar
Since they're $3.50 each at vacuumtubesinc.com, I wouldn't be TOO concerned about finding a sub...
Old 25th January 2006, 12:59 AM   #6
ilimzn is offline ilimzn  Croatia
Sonds like something similar to an UCL21
Old 25th January 2006, 01:28 PM   #7
Send a message via AIM to DigitalJunkie
Are they all microphonic?
All the 60FX5's I've come across were *really* microphonic..
Old 26th January 2006, 06:36 AM   #8
cogsncogs's Avatar
Yup! They're the same, different heater voltage.
A 50HN5 as per above. 50V heater.
A 60FX5 is not quite the same, about half the output power, twice the plate resistance, 150V max plate, and is a 7 pin.
Wayne
Old 27th January 2006, 04:09 AM   #9
Thanks everyone, I was intrigued by this little amp. It is an Arvin pulled out of an old console. I went ahead and bought it just to tinker with, (25.00 bucks). Thanks again, Jayman
Page generated in 0.08844 seconds (76.42% PHP - 23.58% MySQL) with 9 queries
