diyAudio Sponsor
Old 23rd January 2006, 05:09 PM   #1
elementx's Avatar
Default standy switch
where do you install a standy switch on a tube amp to maintain a safe load while removing the output to the speaker?
Also, the princeton amp calls for 1/4" jacks that are closed when there is nothing inserted. is this required? or can i use a regular open 1/4" jack?
Old 23rd January 2006, 09:23 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi elementx,
The standby switches I've seen interrupt the center tap of the secondary for the high voltage. I've seen the odd one turn the heater off of the rectifier tube (I don't like this).
The shorting jack prevents having an open transformer secondary. The short may blow the fuse, possibly damage the outputs. An open may cause the insulation in the output transformer to break down. It would also cause the tubes to possibly arc. Of the two, I choose the short.
Use the shorting jack.
-Chris
Old 23rd January 2006, 09:34 PM   #3
cerrem is offline cerrem  United States
Make sure that the screen voltage as well as the plate voltage are shut down on the output valves..
Chris
Old 24th January 2006, 08:12 AM   #4
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
-Chris
Hi Chris,
Perhaps is better to use the most used solution, an open jack with paralleled a 100ohm 10W resistor you save both things with this
Old 24th January 2006, 01:08 PM   #5
elementx's Avatar
100ohm 10watt in parallel, is that how its done?
Old 24th January 2006, 02:16 PM   #6
anatech's Avatar
Hi elementx,
I've seen that a couple times, just wire the resistor across the output jack. I don't know how effective this will be as the reflected impedance to the tubes is going to be extremely high. I suspect a shorting jack is the better solution.
-Chris
Old 24th January 2006, 03:46 PM   #7
amperex is offline amperex  United States
Place a 20 ohm 25 watt resistor on the 1/4" speaker plug that is disconnected when a 1/4" jack is installed. 1/4" plugs are available with the normally closed contact. See Antique Electronic Supply in Tempe, Az.
As for a standby switch, interrupt the transformer B+ center tap. For best high voltage standoff, use a 240 VAC rated 10 to 15 amp switch & connect the transformer center tap wire to the switch contact that does not have the 'shortest insulated distance' to the toggle part in the interior of the switch. That would normally be the switch lug in the center of the switch body that is say less insulated to ground.
When the switch is in the on position, it connects the CT to ground & no potential above ground exists in the switch. If the switch has a metal (conductive) toggle, make sure it is grounded to the metal chassis. That would exclude plastic threaded switch shafts for mounting.
I am not trying to cause any fear here, just the best way to wire a quality switch. I never experienced a shock from a standby switch nor heard about any internal arcing issues. Obviously, a cheap 120 vac mini toggle switch is not what one would use in this circuit.
standby switch 9am53 Tubes / Valves 17 25th October 2010 12:24 PM
Where do you put the standby switch duderduderini Tubes / Valves 13 4th October 2008 04:39 PM
Standby Switch dre7 Tubes / Valves 6 18th October 2007 08:07 AM
Standby switch for Quad II? Zombie Tubes / Valves 13 13th March 2003 11:20 AM
Page generated in 0.09254 seconds (74.03% PHP - 25.97% MySQL) with 10 queries
