| diyAudio Sponsor | ||
I just finished putting together and doing initial testing on a stereo 801a SE amp. It's resistor loaded with a parafeed type output. I got the original design from Steve Bench's site: http://members.aol.com/sbench/inp_dri.html
Also linked there are discussions on hum cancelling methods and starved filaments, both of which I used. By fiddling with the components, I was able to get to about 0.5mV on the outputs. I suspect that with an oscilloscope, one could do a little better. I made significant changes in only two areas. I used a 0.9H choke (cause that's what I had readily available) instead of 4.5H, and so I adjusted the associated cap to 220n from 47n. The other change was to the value of the bypass cap in the cancellation circuit for the 801 grid. Instead of 2.2u, I found that about 20-40n worked best. I did this by voltage measurent and ear, and could get significantly lower than with the spec.'d cap. I don't know why the value should be so different. A further note on the schematic I used: I had only one 7v filament supply, so there are two compensation circuits, though not shown that way below, that are both run off the same supply. I know this is not ideal and gives me very limited differentiation for the standard hum bucking pot. It works ok with one well matched set of tubes I have. I will eventually replace the transformer or add an additional 7v supply so that I have completely independent circuits. Any comments/ suggestion would be most welcome. I am particularly interested in comments on the power supply. It models well for static conditions with about 3mV ripple for B+ and a fraction of a mV for the driver. But I wonder if the impedence of the driver side might be too high. One mitigating factor is that I'm only using these amps to produce the spectrum above about 300hz. |
#2 |
Oh, and don't blame Steve for this power supply or the bias supply. These were my concoctions.
Sheldon |
#3 |
Bias. I got the transformer idea (common 5V transformer reversed)from Tony on this forum.
#4 |
I think you want to correct your diodes in that bias rectifier drawing. If they were really connected that way they'd be short-circuiting the transformer!
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#5 |
I am assuming that your rectifier is not really a 6X4 - this is definitely not a good choice at the voltages shown.
Kevin
www.kta-hifi.net |
#6 | |
#7 | |
Heater negative with respect to cathode: 450 Volts Positive ditto: 100 Volts PIV: 1250V Current: 210 mA Transient peak current: 1A So in looking at those values, my reasoning was that the heater is floating, so I should be ok. The max. swing with the bridge is a little over 600 volts. PIV is about 650. Current is only about 25 ma Transient peak current only exceeds 1A (about 1.2)for a couple of cycles. With PSUD that assumes the diode is hot on turn on, so I would guess with normal warm up that the peak is less than 1A? So where did I go wrong? Hasn't blown up or acted funny -- yet. Sheldon |
#8 |
Some extra data
#9 |
IMD at around .3-.4w (I think)
#10 |
THD
| 40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? | dtm1962 | Solid State | 10 | 15th September 2011 07:38 PM |
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| power output calculations, rated power and required power output | metebalci | Tubes / Valves | 7 | 22nd February 2004 05:49 PM |
| Page generated in 0.10703 seconds (81.49% PHP - 18.51% MySQL) with 11 queries |
