diyAudio Sponsor
Old 15th February 2006, 04:14 PM   #31
405man is offline 405man  Scotland
Johan and Chris, have you unwound an ESL57 transformer, I would be interested in winding a Quad II output transformer to drive the ESL57s directly, any thoughts
Stuart
Old 15th February 2006, 06:33 PM   #32
cerrem is offline cerrem  United States
Originally posted by Tony
johan, chris,
just to make sure i understand, are the plate windings and cathode windings in phase or not?
by large groups stacking, you mean in groups of say 8 lams or more? instead of the 1 to 1 or 2 by 2 method?
thanks
The Plate and Cathode windings are in PHASE...they must be for the feedback to work...Since the AC signal at the plate is out of phase with the signal at the cathode.... SO the windings are in phase but the signals from the tube are out of phase..
In a McIntosh OPT, you have equal turns in plate and cathode windings and the windings are also in PHASE...this gives 100% feedback, thus UNITY VOLTAGE GAIN coupling... Think of it same as a Cathodyne phase splitter but with transformer loading..
WHen you stack E-I lams by 1:1 ...there is a tiny gap, it can be calculated with accuracy..as you increase the groupings such as 5:5 or 10:10 or all the way up to like a Single Ended OPT with all E's grouped and all I's grouped...the effective gap increases and linearizes the BH loop for a bit more clean head room at expense of lower "effective" permeablity...don't over do it, then you loose too much inductance..but if you already have way more inductance than you need...this is the way to go.... I make my QUAD OPT's with 10:10 groupings of laminations and they sound cleaner and less colorized by the affects of core distortion...
Chris
Old 15th February 2006, 06:36 PM   #33
Stuart
I have given that some thought in the past...but never implemented a plan to do so.... I would love to give it a try..Need more info on the ESL57 High-Voltage transformer...
Chris
Old 15th February 2006, 09:21 PM   #34
Chris,
Your mail #29 (I am not going to quote) is most clear and you have obviously done more on the output transformers than I did - I only repaired, I think, 2 long ago, although as said I have designed a few for my own stuff. Also apology for overlooking the turns given. I am usually posting after midnight here, perhaps not a good idea:xeye
I then also misunderstood you (I think I missed a post) regarding the many cathode sections; that was your own design and not the original I cannot add much more, except to perhaps give figures I measurted on the OPTs of 2 Quads in my possession (serial numbers 53125 and 49000 - would you believe it).
Inductance of full primary at 5V 50Hz: 39 Hy and 34 Hy
Leakage reactance at 1 KHz, full primary to secondary shorted: 11 mH and 11,2 mH
Anode primary (XZ) to shorted catode winding (UW shorted): 113mH and 106mH
Just as an exercise I calculated the anode/cathode winding leakage with some guesswork as to dimensions (but no back-engineering!) and got 118 mH, so everything seems to fit.
Yes, the leakage anode/cathode winding is rather high; - 3 dB response at 9 KHz calculated (I did not measure). But that excludes the further coupling caused by the interleaved secondary which could lift the frequency slightly.
Tony,
Likewise I have not yet ventured that far but there is a guy here in the RSA that has done that. I will try to trace him and post his experience when I am able to.
Johan
Old 14th March 2010, 11:05 PM   #35
pred is offline pred  Switzerland
Hello all,
I recently become the owner of Quad II. I was reading most of the threads on this topic but still had some questions to ask. I did not want to open a new one so I decided this is the best to what I want to ask.
My quads are with all original tubes in great condition (checked on the tester, all 4 GEC tubes are around 60mA and Mullard GZ32 and EF86 are all in good shape).
But:
As someone noted after two hours of listening my amps (specially the choke) are very hot. I can touch the choke but I would say it is like 50°C. Also I feel that the power transformer is just hot (much less, I would say 45°C) but from the tubes near by, since this side is hotter then the other one.
Since there is no power switch I hope the amps were designed to work with these temperatures (hopefully even after 50 years) even for a prolongued amount of time. Do you have the same experinece? Is someone listening to them for more then 2 hours? Will change to GZ32 and 6l6 types without coke bottle shape change the temperature much?
Thank you in advance,
Pred
PS
Please do not recommend me to change the amp, it is for me match from haeven with my Focals
Old 15th March 2010, 12:21 AM   #36
Hi Pred,
No need to change the amplifiers (to what I wonder) - but perhaps something in the amplifiers. Yes, they do get hot, but in Switzerland? OK, perhaps ignorance; we foreigners always think of Switzerland as cold only.
If you say 'original tubes', I take it you mean classic shape KT66s. These days one also gets Coke bottle shaped Russian ones. STAY AWAY! With them the glass does come too near the output transformer and heat it up. What's more, the insides of those are exactly Russian 6L6GBs - only here they cost twice as much! On output valves, change to 6L6GCs (when necessary) is advantageous. The heater current is less but the maximum plate dissipation more than for KT66. The characteristics are within 10%. (And for heavens sake, do not use with EL34s!)
A point (pardon if you have read this in the thread previously; I did not check): I presume you have 230V 50Hz mains. The Quad power transformer was a little over-designed voltage-wise (probably OK with all ancilliaries connected). Keep your mains setting (the screw on the side) at 240V. Then replacing the ugly old GZ32 with GZ34 is advantageous. It operates cooler, and h.t. rises to about 370V. This is still within the limits for valves, and will give a quite clean 17 - 18W.
Pred, inside you can change one item to make a difference. The hot KT66 cathode resistor sits right under the choke. Firstly, I change that to a 10W resistor; the rated 3W resistor works at maximum. Then bend that away to the output transformer side of the mounting terminals on the choke (to the other side, it will fry the cathode bypass electrolytic). If the amps have worked for some time, that capacitor would already have been compromised - on refurbishing many Quad IIs I have never found one that was still in order.
Regarding a power switch, that came with the Quad pre-amp for which the IIs were designed (the power amp power chord came from the pre-amp).
These amps should be able to work for long times when well ventilated. If there are still heat problems after the above, I fear that someone competent (if not yourself) must check matters out. There are also other item changes one can make after 50 years, but not to make this post too long.
I hope this helps; you can also PM me.
Old 15th March 2010, 08:09 AM   #37
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Quad IIs run hot. As Johan says, replace that cathode resistor and capacitor immediately. Make sure they have good ventilation. I assume you have cleaned all the dust off...
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 15th March 2010, 07:25 PM   #38
Hello,
thank you both on the answers. Well I am versed in electronics so I will remeasure the amp over the weekend (if I find time, 2 small children ) and report to you. I want to change this awful rifa with some mkp that I have around.
I think it is the GEC valves and GZ32 (I like the looks of this tube!). The guy that I bought the amp from did some mods, well updates of the components. You can see on the picture that coupling caps are Jensen PIOs and that the cathode resistor is a 5W at least, I would say more like 7W. Is it far away enough? The capacitors are cerafines, I do not know what is the value. For the electrolytic he told me that he reformed them with slow rise of voltage, by 50V every hour. Resistors, except two are changed but this should not be a reason. I will see but I feel not comfortable with the heat. The amps are on the top of my hi fi shelf so they have plenty of space around and above them. The amp runs from 230V mains and I plugged the thinggy into 230-250 tap.
I do not feel I need more power, this is Switzerland, neighbours get disturbed easy What is your opinion on JJ GZ34, is it reliable there are some guys on ebay selling them cheap and I would like to try. If I see the heat dropping then I would maybe try a pair of 6L6GC just to see the effect and if all is good to go and find some nos tubes, and sell GEC for a fortune (anybody interested )
Here is the photo of the amp and any comment would be helpfull
Pred
PS
There is a joke about Swiss. " Last year the summer in Switzerland was on tuesday".
Old 15th March 2010, 11:39 PM   #39
Hi Pred,
Do you have a circuit diagram? Sorry not to have a reference right now, but it is readily available. (Mine came from www.geocities, but I believe they do not exist any more.)
If so, then there are several further matters. Firstly about that hot resistor (R12). In your photos it still sits right under the choke - that will heat it up as previously said. You can either use longer leads and move it right over to the output transformer side out from underneath the choke, Or perhaps more practical, move it over to where the capacitor is at present (C5) or even closer to the rectifier socket. Get it away from right under the choke. You can instead mount the capacitor C5 straight over the tie-poins on the choke terminal board - you would have realised that those terminals are just convenient tie points; no connection to the choke inside.
Then second important point. It is frequently found that the two Hunts coupling capacitors C2 and C3 are leaking. This is measured easiest by checking that the KT66 bais voltage is not significantly higher than 26V. It is difficult to measure the grid dc accurately even with a 10meg input digital multimeter. Easiest is to again measure the voltage over R12 with C2 and C3 connected, and then without them connected - the bias reading should be the same as you will guess. Obviously, if there is a difference, C2 and C3 will need replacement. (And here - though I may step on toes - please dispense with spending a whole lot on boutique capacitors. Polyester/polypropilene is quite satisfactory.)
For an initial test on heat generated: Take out all the tubes and leave the amps running for some two hours. Then replace all but the GZ32, and test again. Over both runs they should remain cool - luke-warm transformers. You might now attend to C2, C3. It would have been more direct to do the previous voltage measurements over R12, but you can also disconnect C2,C3 from the KT66 grids (pins 5). Running the amps that way; if they are cooler, would also indicate over-current in the KT66s as a result of leaking C2, C3s. (If you measue KT66 grid voltages, do note that there is about +0,6V on G1s - the grid resistors R7, R8, R9 are not going to common but shares some potential from the EF86 cathodes network.)
Then, should you replace C2, C3, it will probably be with ones without a metal sheath clamped to common. Those metal sheathes place about 18pF capacitiy from each G1 to common. Leaving that out is not serious, but if you have access to a 'scope and square wave generator, you will notice a slight overshoot on the leading edges. A rather better way to correct for the mentioned 18pF is not to replace them, but to do a phase advance correction over R11 - one places a 1nF - 1,2nF capacitor over R11. The results should be visible on the 'scope.
While this is already long: I mentioned that I often left the capacitors C4-C6 alone. They were still good, and it can be a schlepp to mount other types neatly. If you are of an industrious nature, you can replace the caps inside the tin and retain the original appearence. C4-C6 is a round double-C inside that square tin. With a hot soldering iron it is not much of a problem to unsolder/pry open the bottom of the tin - it comes off. The cap inside will be secured by some pitch at the bottom; not too much of a job to get it out and get the tin clean - I fear the lettering will suffer. Then one gets good enough modern smaller Cs to enable one to mount them back inside the tin. A sophisticated double C I used (expensive) was the 50µF + 50µF 500V made by JJ. With some patience and not too much heat (you say you solder for a profession!) the original appearance can be restored and the 'tin' resprayed 'machinery grey'.
As an engineer I appreciate the advantage of silicon rectifiers. But they also provide instantaneous h.t., and cathode stripping of the tubes is a practical danger - apart from having to deal with a peak initial h.t. surge.
To plead moderation: If you consult the internet, folks come along with wonderous 'tweaks', almost changing the design. Grid stoppers, fancy wire, fancy capacitors, twin RCs for the KT66 cathodes, goodnes knows whatever. I have restored my modest few, and I can assure you that none of such tweaks make a difference. One keeps the amp as close as possible to the original, which is mercifully possible in this case. If one wants a more fancy amplifier, one goes and buys something else. Peter Walker was not stupid, and used the design he did for a reason.
Sorry for a rather lengthy missive; these from my experience. (And I did find relocating R12 important!)
Old 15th March 2010, 11:57 PM   #40
tinitus is offline tinitus  Europe
Looks like one of the new later "copy" version, and not the genuine old original ?
Marantz PM66 KI tweeks Fidelity Audio Solid State 462 7th February 2012 05:41 PM
Quad 405-2 mods - which ones? centaurus3200 Solid State 2 31st October 2006 12:30 AM
Quad CD player mods mickhick1 Digital Source 1 7th October 2004 06:11 AM
expert tweeks for PA? Pbassred Multi-Way 4 7th December 2003 08:57 PM
Aleph mods for quad 57? jonk Pass Labs 5 1st May 2003 11:05 PM
Page generated in 0.18946 seconds (78.11% PHP - 21.89% MySQL) with 11 queries
