diyAudio Sponsor
Old 21st January 2006, 04:27 PM   #1
Question Trying to recreate a Fisher SA-16
I’m trying to recreate a Fisher SA-16 But making it in to monoblocks. OR having to a chassis for each channel. I can also go with three chassis one for the powesupply and one each for each channel. I have a fisher SA-16 at home which is giving me problems but no big thing. So i have a good reference and theres also schematics. Do you guys think is a good idea to go with any of these ideas or should I just try to recreate without modifying the look.
http://www.quadesl.com/pdf/sa16.pdf
Old 21st January 2006, 09:22 PM   #2
Joel is offline Joel  United States
Joel's Avatar
I did my own take on the SA-16, except I used the book class A bias point for the EL84's, and no UL. It's in a mono format. I also used Magnequest nickel-pinstripe 8k p-p output transformers, but I'll bet the Fisher's are good quality.
It sounds really good so far, but more extended listening tests are needed.
http://www.joeltunnah.com/images/jt_...e_01-18-06.gif
Fisher 55-a mattos1969 Tubes / Valves 13 15th September 2011 04:13 PM
fisher xp 60c tim614 Multi-Way 0 6th July 2008 02:51 PM
Fisher xp 7b marktd Multi-Way 2 17th October 2007 12:51 PM
Fisher 500-C crick Parts 0 8th July 2007 05:43 PM
fisher amp wev Solid State 10 25th October 2005 08:54 AM
Page generated in 0.08978 seconds (60.45% PHP - 39.55% MySQL) with 10 queries
