Does anyone have any experience with this 1:4 interstage? Their site gives its specs as +/- 0.5 db max. from 20 Hz. to 20 Khz - seems the best I've found (for the money).
I was considering 01A --> 850Q --> 01A --> 71-A or 45, single ended of course.
Damn 01-A's can't swing the 80V by themselves.
Joel
Joel
Joel said:colt45,
I AM one the radio fanatics! Regularly pick up Radio Havana from Cuba with a single 01-A as a regenerative receiver. That's 1,200 miles. Not bad for 1925 technology.
Joel
Cool, ive been thinking of doing that as well.
I'd need an interstage tranny and a 4pin socket though, which I am lacking at the moment.
no iron necessary
I know it's a bit off-topic, but here's the schematic I drew up for that receiver I've been using. There's no step up transformer needed (since the detector is the audio amp as well. You will need a set of high impedance headphones though (1,000 to 2,000 ohms). All of the parts are very cheap. Angela Instruments, or Antique Electronic Supply have 4-pin sockets.
ok, cool.
I was going to replace the headphones with an interstage, and feed it into a 6V6 or some other pentode.. maybe something that likes a nice low B+. (maybe a gain stage between the two tubes, i suppose..)
so I can drive a speaker with it.
whats the specs of the two coils marked T and S ?
I'd order a socket from somewhere, but by the time it gets here, and i pay for it, and shipping.. well its just not worth it for a measly socket.
I suppose you could probably make an ok regen reciever with a 6SN7 or 12AU7, etc etc,. first half for detector/amplifier, second as a gain stage to drive an amp..
(i might as well use one of my 01c's, they're not doing much good sitting here.)
colt45,
You need the headphones. Distant stations are tough to hear, and listening on a big speaker would be fruitless, even with the extra amplification. www.tubesandmore.com has them for $17
"S" and "T" are coils wound on the same form, 1/8" apart from each other. I use a 4 pin tube base from a burned out 01A. Any base would be fine. I have "S" as 16 turns of #24 enameled wire, "T" is 9 turns. This seems to bring in stations in the 5-8MHz range. Make sure both are wound in the same direction.
So, actually you need two 4-pin sockets, a tube base, probably a rheostat and the variable capacitor? Now it may be worth an order, huh?
Joel said:So, actually you need two 4-pin sockets, a tube base, probably a rheostat and the variable capacitor? Now it may be worth an order, huh?
ive got pretty much everything else.
Ive got an old radiola III-A too, but the interstage is ******ed.
(not to mention that WD-11's are way too exepnsive..)
- Tubes / Valves
- Hammond 850Q Interstage?
