diyAudio Sponsor
Old 20th January 2006, 12:49 AM   #1
leadbelly's Avatar
Default Is feedback required for UL EL84PP?
I'm still debating whether to build my EL84 amp as UL or triode or with a switch for both. One consideration, do I need a negative feedback circuit with UL connection? The majority of vintage UL EL84 schematics I have seen do include a negative feedback circuit from the OPT secondary to the input stage, but then I came across this schematic which made me question this:
http://www.electra-print.com/images/PSA_EL84_reva.pdf
Comments? Suggestions?
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 20th January 2006, 03:00 AM   #2
I recently built my first UL amp (after building a few triode amps) using 6AQ5's. I did not want to use global negative feedback if I could avoid it, but just hooking the screen grids to the UL taps was not enough. UL is a form of local negative feedback, so I tried inserting some series resistance to control it. It worked! I ended up with 300 Ohms in between the taps and screen grids, and it sounds great. I would try with no resistance first, then add resistors in steps until it sounds clean.
My circuit is similar to that one, except that I use a triode for the input stage and use an interstage transformer instead of the cap/choke combination. Either way works. I think you will find that it is easy to get working and sounds very good!
Old 20th January 2006, 01:41 PM   #3
leadbelly's Avatar
Thanks! When you say that your design was similar, did you also leave the cathode resistor of the EL84 unbypassed as shown in the above schematic? I guess that is also local feedback employed by that amp.
Old 20th January 2006, 02:34 PM   #4
I have a Leak Stereo 20 which is much modified, but taking off the feedback loop in UL was a breakthrough in sound for me. Much more natural. I agree - try the 300 ohms resistor. Andy
Old 20th January 2006, 03:32 PM   #5
Yes, my understanding is that the bypass caps are not required in the push-pull circuit, so I only use caps on the input tube cathode.
Thanks Andy, for confirming the idea that global neg. feedback is best avoided!
Old 20th January 2006, 06:04 PM   #6
kopite is offline kopite  New Zealand
My current amplifier is the circuit you have pointed out from Electraprint. My previous build is a se EL34 but this amp beats it easily for sound quality. The 6au6 in triode mode is a very underated tube. The phase splitting transformer works very well.
The circuit is easy and well thought out. Give it a try and report back your findings.
Phil.
Old 20th January 2006, 09:54 PM   #7
Hey-Hey!!!,
If the speakers don't do anything screwey, a very high output Z amp can drive them. Think all-pentode. But if you need a bit more NFB and still don't want to do the nasty loop thing...try this one.
It works best with pentodes in the front stage.
cheers,
Douglas
the Tnuctipun will return
Old 23rd January 2006, 02:09 AM   #8
Default Yep - a bit is required
Leadbelly,
See my post here for what I do:
Is this EL84M UL PP OK?
I use some shunt feedback (local feedback) and a small amout of global feedback.
Ian
Old 23rd January 2006, 10:23 AM   #9
gingertube - you were threatening to post aschematic of your EL84 amp - would be ijterested to see it + the CCS in the output. Andy
Old 25th January 2006, 12:02 AM   #10
Default Reply to Andy
Andy,
Posted here:
EL84 Amp - Baby Huey
The CCS for the output tubes is on page 2. Note I use separate CCS for each tube to allow Class AB operation.
Ian
Partial Feedback EL84PP - Not quite as expected (yet) Svein_B Tubes / Valves 44 18th May 2008 04:59 PM
New Jensen caps has no bass in..Simple EL84PP aroS3 Tubes / Valves 5 8th December 2006 04:29 PM
amp feedback required pgbhat Solid State 2 19th October 2005 01:43 PM
Mosfet class A p/p amp... is feedback required? nobody special Solid State 13 11th September 2004 06:30 PM
Help required regarding optical motional feedback theories eclipse Multi-Way 27 6th April 2004 03:03 PM
Page generated in 0.10522 seconds (77.77% PHP - 22.23% MySQL) with 11 queries
