diyAudio Sponsor
Old 18th January 2006, 06:20 PM   #1
Default Line preamp using 2 ecc88 per channel
This circuit is taken from the Stereo VOL:66 march 1995 (Hi-Fi magazine published in Italy) and presented by Fulvio Chiappetta.
V DC=225V
Both tube V1 & V2 =6922 or ECC88
C1 100nf 400v
C2 2,2mf 400v
C3 1000mf 400v
C4 100nf 400v
C5 2,2mf 400v
Specifications:
Amplification factor:20dB
Input resistance:22k
Input capacitance: can be omitted
Output resistance:< 100 ohm
Distorsion in audio bandwidth@ 1 Veff: II harmonics -62dB
III harmonics -68dB, IV harmonics -75dB V harmonics -81dB
Signal and noise ratio @1 Veff out: 90dB
Max output voltage:>100Vpp
Please debate and discuss this circuit, factors that affect this
circuit in term of electrical behaviour & etc that contribute to stability and sound wise.
Old 18th January 2006, 07:36 PM   #2
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Hello! An Italian
Are you sure you need all that gain?
I must also add that ECC88 are not my best flavour. There are many better tubes out there, almost forgotten...
Old 18th January 2006, 07:56 PM   #3
Hi Giaime,
Not to pull the thread off track, but what are your favorite tube flavors for a preamp?
Old 18th January 2006, 08:12 PM   #4
lineup is offline lineup  Sweden
lineup's Avatar
Originally posted by Giaime
Hello! An Italian
Maybe better to put these two ECC88 in parallel.
Will lower gain and increase drive capacity to a nice level.
Not that I know much anything about tube circuits.
lineup
Old 18th January 2006, 09:07 PM   #5
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
I don't like SRPP
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 18th January 2006, 09:33 PM   #6
leadbelly's Avatar
It's not really a line preamp at all, gain is too high, so high it could actually overspec some SS amps at 100Vpp. It's a high gain input section. Even the caption does not call it a line preamp.
6922's and ECC88's are great
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 18th January 2006, 09:43 PM   #7
Zen Mod's Avatar
Originally posted by choky
I don't like SRPP
edit time just 30 min. ....
even if I don't like SRPP,I like ECC88
better way for line stage (even if gain with 88 is on highish side) is to use two systems in one envelope in parallel,and make that line stage as anode follower if Zout is adequate;
if lower Zout is needed,than CF must be used-say-just one system of 88 for that (1 per channel )
one bottle per channel in WOT configuration is almost a killer!
Old 19th January 2006, 07:46 AM   #8
andrei is offline andrei  Canada
Getting back to the schematic rather than tube flavour chat...
It looks to me like the quoted distortion figures are a bit optimistic. For 1V input signal and 250V B+, it simulates to about 0.5% THD (-46dB). This is a factor of three lower than standard resistor-loaded common cathode stage would give you at the same bias, but the effect is almost entirely due to the negative feedback through unbypassed cathode bias resistors. The power supply noise rejection is nothing special - the usual 6dB. The output impedance is low (the output stage being cathode follower), but the bias current is only 6mA, so it will only drive 5k load at rated 100Vpp output (clipping sets in abruptly at about 4k load).
Old 19th January 2006, 08:56 AM   #9
marziom is offline marziom  Italy
that's seems a SRPP stage that drive the upper valve (V1b) of a push-pull stage.....but the signal of the two drive are unequal....
marzio
Old 19th January 2006, 12:00 PM   #10
Giaime's Avatar
So I haven't seen a positive post on that design
Mikewong, I think it's better to change design. You have 3 options:
1) you're a Tube Guru (like me ) and you will/can experiment and draw your own circuit.
2) Get TubeCAD. It's wonderful.
3) Have you looked at the Aikido? Or the SY's Heretical Gainstage? There are many linestages out there, some of them use strange tubes (not so used for audio but easily obtainable) that can sound very good (and they're cheap).
About tube flavours, before you judge the ECC88, try a EL84 trioded
Circlotron Preamp with ECC88. Circlomanen Tubes / Valves 13 19th August 2006 08:27 PM
home theater with 2 channel preamp bonsai171 Solid State 1 3rd June 2006 11:28 AM
2 channel preamp recommendation please gary h Solid State 0 29th April 2006 02:05 AM
6 Channel Preamp Project DC Dave Chip Amps 7 6th December 2005 02:00 AM
NEWBIE needs help-static in one channel of preamp jj69 Tubes / Valves 5 27th June 2004 10:49 PM
Page generated in 0.10233 seconds (79.62% PHP - 20.38% MySQL) with 11 queries
