| diyAudio Sponsor | ||
Here is a neat little trick to try for your next preamp project:
#2 |
looks like a circuit done in switchcad... what are the results?
#3 |
would that arrangement introduce positive feedback?
#4 |
The cool thing about this gain stage is that it draws constant current from power supply, and so does not require cathode bypass capacitor. Load drive ability is pretty good, too. I've drawn the component values for russian 6N30P tube, but almost any other small-signal triode can be used (5687 comes to mind).
For 1V input, simulation gives THD ~0.5% (second harmonic mostly). As the bias is at -7V, the headroom available is very large. Comments? |
#5 |
Despite appearances, there is no feedback to cathode resistor. The symmetry between two stages makes the current drawn by common cathode amplifier (U1) and cathode follower (U2) to be the same in value, but in anti-phase, and to sum up to a constant current through cathode resistor (which provides a constant bias without capacitor). The current drawn from power supply is this constant current plus the (small) load current, so one can use a very high impedance power supply with a small decoupling capacitor.
#6 |
has this been put into a prototype yet? i have some 5687 tubes here waiting to be used...
#7 |
No, simulation only so far. I have an integrated amp, so I don't really need another preamp, but I'm tempted to layout a PCB for this just out of curiousity...
#8 |
i can make a proto of this point-to-point after my 12B4 pre is done.
3.3uF output (coupling) capacitor ok with this? |
#9 | |
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
#10 |
Output coupling capacitor value together with load resistance will set DC cutoff frequency. 3.3uF into 10kOhm load gives cutoff at 5Hz, which is more than enough. Even 1uF will do. Same goes for PSU decoupling capacitor, BTW. I would go for a smaller value capacitor with better dielectric. You can get away with no electrolytics alltogether with this circuit. To get a quiet power supply, one can use a solid-state CCS (like IXUS IXCP10M45S).
Re:bias There is about 7V DC drop across R2, so the grid of the tube U1 is biased at -7V relative to cathode. Both stages draw 20mA idle each. (This is for 6N30P, for 5687 the resistor values would be a bit different.) |
| Berman 76 preamp schematics | arnoldc | Tubes / Valves | 1 | 2nd January 2011 11:51 PM |
| Preamp design schematics done | Skywalker83 | Instruments and Amps | 6 | 1st January 2009 04:53 PM |
| 6H30P preamp schematics | Mrpong | Tubes / Valves | 18 | 6th November 2008 08:47 AM |
| ecc preamp schematics please!!! | kianbach | Tubes / Valves | 1 | 7th May 2005 12:31 AM |
| Old link to preamp schematics | beppe61 | Solid State | 0 | 8th February 2005 11:51 AM |
| Page generated in 0.10458 seconds (74.27% PHP - 25.73% MySQL) with 11 queries |
