diyAudio Sponsor
Old 16th January 2006, 09:28 AM   #1
Katapum is offline Katapum  Europe
Default Best cap to cathode tube bypass is …..
Hi all,
I’d to know what is the best cap to cathode tube bypass. The 300B amp needs a 120uF/6.3Vcap.
I have in my place:
Panasonic FC
Rubycon YXF
Sanyo oscon
Elna RJH
Any comments or suggestions are very welcome (and sorry my English).
Katapum
Old 16th January 2006, 09:35 AM   #2
Send a message via AIM to DigitalJunkie
I dunno about the best,but I've heard the Oscon's are pretty good for cathode bypass duty.I havn't tried it myself though,yet.
6.3V ? are you sure about that? Seems low to me..
Old 16th January 2006, 11:49 AM   #3
SY's Avatar
Where in the circuit is this used?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 16th January 2006, 11:55 AM   #4
You can get 100uF in motor run caps. Big, but good. I use ICW polypropylenes rated 160uF. Big but very good.
Old 16th January 2006, 02:23 PM   #5
in input stage (not in 300B stage).
Amp has no room to big caps.
Katapum
Old 16th January 2006, 03:08 PM   #6
Andy,
I've been thinking about using motor run caps for bypass. Were they noticeably better sonically than good elctrolytics (BG or other)?
Jonathan
Old 16th January 2006, 05:21 PM   #7
SY's Avatar
Why not lose the cathode bypass cap and bias up the input tube in some cleaner way?
Old 16th January 2006, 07:47 PM   #8
Could you elaborate?
(Input tube is a triode; the amp has only two stages with no feedback.)
Katapum
Old 16th January 2006, 07:49 PM   #9
SY's Avatar
If you can sketch out the input stage, perhaps we can look at some alternatives.
Sorry, I just hate cathode bypass caps. Nasty things.
Old 16th January 2006, 07:54 PM   #10
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
If you can live whitout 3dB of gain, what's the problem? Just leave it out! Stuart, am I wrong? Does the first stage need to be fully redesigned? Just make up for the lost gain with a little increase in plate resistor (or tube change)...
2A3 without cathode bypass cap??? papparazzi Tubes / Valves 13 25th May 2008 04:06 PM
Calculating cathode bypass cap. G Tubes / Valves 8 12th April 2007 04:50 PM
Which BG cap best suited for cathode bypass? reaction Tubes / Valves 10 25th April 2005 07:43 AM
Cathode bypass cap ? woody Tubes / Valves 2 19th May 2002 05:53 AM
Best Cathode Bypass Cap Mohan Varkey Parts 4 6th May 2002 08:59 PM
Page generated in 0.08699 seconds (79.03% PHP - 20.97% MySQL) with 11 queries
