| diyAudio Sponsor | ||
I think this is a stereo valve amp but am not sure what it.
Does anyone here have any ideas |
#2 |
Hum,It definatly looks like a stereo PP setup.
The trannies almost look like they are the same ones in a Dynaco ST-70. Looks like it was an Organ-amp,or part of a console? 7591 output tubes? (hard to tell in the pic) |
#3 |
It's an AMI/Rowe jukebox amp. Have one very similar under the bench, sourced from E-bay for the iron.
#4 |
Now the whole host of other questions. But I thing a quick google first.
Thank you. |
#5 |
Ahh so parts aren't a problem but could it be used as home hi fi amp?
#6 |
No idea at this point. Two medium-power OPTs and a power tranny for $50 was too good to pass up. I recall stumbling across a few internet posts praising the iron quality. I also like the true balanced out - it appears the output taps are symetrical to a centre ground tap - and the 70 volt windings. The two suggest some interesting options for feedback topology which I haven't really investigated yet. The only possible negative heard so far, and I'm not 100% it related to these specific models, was that some manufacturers tended to run jukebox power tubes at very low current to extend service life. It does suggest caution regarding output biasing is warranted when working without a service manual.
Honestly I really haven't done more than check out the wiring so far. Too many other projects on the go. |
#7 |
Well I haven't got that far.
Looked at it and thought ahh bit of interesting soldering so was thinking of checking it over and may be getting a rebuild kit of valves and resitors. Then giving it a go. |
#8 |
Well it's a bit useless as I don't have the pre amp.
Oh well. Anyone gaot a preamp for one of these? |
#9 | |
The only source that requires a preamplifier is vinyl. Everything else will drive your amplifier directly. Just add a volume control, and if you're feeling fancy, a selector switch.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
| Swap Shanling CD-T80 valve CD player for Quad valve equiment | johnm | Swap Meet | 2 | 24th September 2009 12:15 PM |
| somebody can recognise this elna? | netherlands | Parts | 4 | 23rd June 2009 03:18 AM |
| Anyone recognise this amp? | tubewade | Tubes / Valves | 7 | 16th December 2007 10:15 PM |
| how does one recognise ..... | alecwek | Parts | 3 | 22nd July 2004 08:27 AM |
| Does anyone recognise this arm? | dhaen | Analogue Source | 6 | 7th September 2003 08:59 PM |
| Page generated in 0.08804 seconds (75.11% PHP - 24.89% MySQL) with 11 queries |
