diyAudio Sponsor
Old 15th January 2006, 08:02 PM   #1
Question 4 volt (dc?) heater from 6.3v
Hello,
I'm starting on my next project: http://www2u.biglobe.ne.jp/~tossie/KT44UL-E.html
I'm looking for a solution for the next "problem"
The KT44 has a heater voltage of 4volts 2amps ( http://www.r-type.org/exhib/aad0021.htm )
I have some options:
1: using a separate transformer for 4Volts 4amps, difficult to obtain, too many transformers on the chassis.
2: using diodes or resistors to lower the voltage with 2.4 volt (too much dissipation)
3: using the 6.3 volts/8 amps from my transformer and lower the voltage with a low-drop (switching or analog) voltage regulator to obtain 4 volts 4 amps
Before I work on option 3, is there anyone who has another nice solution for 4 volt heater supplies
Old 15th January 2006, 08:35 PM   #2
Tweeker is offline Tweeker  United States
Another approach is a ~2.7mH inductor. CRC to drop any remaining excess voltage.
6.3VAC-rectifier-L-C1-R-C2-heaters.
C1 voltage is 6.3*.9-diode drop=~5V.
Or you can run the two heaters in series at 8V. Rect-C-R-C. Likely little if any R would be needed. Schottkys are recommended in all cases.
Be sure your foil hat has a good low impedance ground.
Old 15th January 2006, 08:41 PM   #3
poobah is offline poobah  United States
poobah's Avatar
Unless you employ switching techniques, you have to "burn" the power (make heat) A resistor is cheap and will give you some amount of soft start in the heater circuit and prolong it's life.
Diodes, linear regulators etc... will all give you the same dissipation once all is said and done.
If you want to power your heaters with DC putting the R between caps in in CRC filter is attractive after a bridge rectifier.
The bridge rectifier will also also knock a couple of volts off for you (although you caps will want to charge to the peaks which are higher anyway).
Beware of one thing when using resistors... if you have multiple 4 volt heaters in parallel, a open failure of one heater will cause the remaing heaters to run at a higher voltage. Presumably, you would be smart enough to power down before any real damage was done.
Old 15th January 2006, 09:02 PM   #4
An inductor does not have to burn off any voltage, use 3mH so its stays critical if one heater opens. Id use Schottkey rectifiers for rectification for DC quality reasons. One could make a sort of CRC that always drops the same voltage regardless of load by using diodes, not sure how the filtering would compare.
Example:
6.3VAC-Schottky->L-C-pn diode(s)->C- heaters. No noise* from the pn diode as it never experiences reverse recovery.
*excluding Johnson noise etc. Inductor critical value of 3mH for 1 heater estimated for 50hz power, bridge Schottky rectifier, and +10% mains overvoltage.
Old 15th January 2006, 09:21 PM   #5
poobah's Avatar
The inductor does that by narrowing the conduction angle?
Old 15th January 2006, 09:34 PM   #6
I think its wider actually.
Old 15th January 2006, 09:38 PM   #7
poobah's Avatar
I gotta learn this "inductor input" PSU stuff... not getting it. And I build sine invertors and PFC rectifiers!
The shame of it all...
Old 15th January 2006, 09:41 PM   #8
Running the heaters in series at 8V with CRC filtering would be the easiest solution, if one heater dies the circuit goes open and the other heater shuts down.
Schottkys and plenty of capacitance would be recommended to be sure you get 8V.
Old 15th January 2006, 09:43 PM   #9
poobah's Avatar
I have runs the sims on that... it hard to get over 7 volts without HUGE caps.
Old 15th January 2006, 09:57 PM   #10
If you decide to use an inductor, use an iron / ferrous cored one, much lower EMI than an air core.
Think of inductor as like an electrical flywheel with a clutch whos losses are mostly DCR. Inductance corresponds and flywheel weight and diameter, frequency with speed, thus reactance goes way up at higher frequency. Its got momentum and wants to keep the same speed/current. When the voltage from the rectifier is below it it drags it up, when its above it drags it down. Thus with a perfect inductor the output equals the average voltage (peak *.636 for sine, which comes to RMS AC*.9), not to be confused with RMS voltage.
This analogue might not be perfect, but it works for me.
how to wire 6.3VDC heater on a heater with center tap (12.6V series, 6.3V parallel)? jarthel Tubes / Valves 9 14th April 2012 05:36 PM
Switching 230 Volt Transformer to 120 Volt OMNIFEX Parts 10 6th April 2008 04:34 PM
ECC99 Heater / Cathode Max Volt Peter Menting Tubes / Valves 5 23rd July 2004 12:29 AM
300B mesh plate, 2,5 Volt Heater reinhard Tubes / Valves 6 2nd September 2002 01:54 PM
Page generated in 0.10002 seconds (81.24% PHP - 18.76% MySQL) with 10 queries
