Which 6SN7 preamp should I build?
Old 27th July 2010, 11:23 AM   #41
porkchop61 is offline porkchop61  United States
porkchop61's Avatar
Here's the one I'm using:
A lot of people here helped me with the circuit design.
I think removing the .047uF cap is the only change I've made.
Glenn
"Imagination is more important than knowledge"
Old 28th July 2010, 04:02 AM   #42
alexg is offline alexg  Philippines
alexg's Avatar
Glenn
Hi Glenn,
I am planning on building this preamp, what is the diode for on the connected to the grid of the second triode?
How many ma across per tube (two triodes)?
Thanks.
Old 28th July 2010, 11:39 AM   #43
porkchop61's Avatar
Hi Alex-
Read post #28 by Sy:
12AY7/6SN7 preamp PSU check
Current draw is the 5.6mA on the schematic (per tube).
The thread I posted above has all the questions I asked about the power supply for this preamp. It's been a while since I built this, so I don't remember what I wound-up with for total current draw from the PS.
Good luck
Glenn
Old 28th July 2010, 12:14 PM   #44
porkchop61's Avatar
I found the PS schematic.
Note that the rest of the schematic is not current, so use the schematic in the previous post!!
Old 11th August 2010, 12:10 PM   #45
porkchop61's Avatar
You know, I should mention that this is not really a preamp. I think it has unity gain. The reason I use this is to give my CD's that tube sound.
I just thought I should clarify this.
Old 11th August 2010, 12:58 PM   #46
Brit01 is offline Brit01  United Kingdom
Trying to figure out why it is a unity gain config.
Common cathode followed by CF no?
Won't there be an amplification of ~20?
Please correct me if I'm wrong or not understanding something here.
If this provides no gain then maybe a better option to a CF between my cdp and ss power amp for that tube warmth.
Old 11th August 2010, 07:27 PM   #47
piero7 is offline piero7  Italy
piero7's Avatar
Originally Posted by vince76 View Post
hi guys,
I want to try this preamp (6sn7 version).
Can anyone suggest a schem for the PSU section?
I would go with a SS rectifier
V.
Use the Salas high voltage shunt regulator
Simplistic Mosfet HV Shunt Regs post #1150
Old 11th August 2010, 07:36 PM   #48
On Hiatus
SY's Avatar
Yes, it is. And no, more like about 10.
A well-designed cathode follower will NOT add warmth; it won't add anything. A poorly designed one could possibly give you excess 2nd harmonic distortion which you might perceive as warmth.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 12th August 2010, 12:08 AM   #49
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
It's a polarity protect diode that keeps the control grid from going positive during power up. It shouldn't really be necessary since 6SN7GTBs were designed for operation in Class *2, and the control grids were hardened and equipped with radiator "wings".
You could also avoid the diode by separating heater from DC power. Power up the heaters before turning on the HV DC, and positive grid voltage won't be a problem.
Otherwise, the diode adds a non-linear, voltage variable capacitance to Cgk. Not having nasty, non-linear, voltage variable capacitances is one of the advantages that hollow state has over solid state.
There are no foxes in atheistholes
www.dolphin-hsl.com
Which 6SN7 preamp should I build?Hide this!Advertise here!
The complete 6SN7 preamp Joel Tubes / Valves 103 14th March 2008 10:32 AM
line preamp using 6SN7 instead of 12AU7 JPS Tubes / Valves 11 23rd May 2007 12:05 PM
Help with 6SN7 preamp tubedude63 Tubes / Valves 7 9th October 2006 12:31 AM
Joel's 6SN7 preamp (photo) Burnedfingers Tubes / Valves 48 2nd March 2003 12:00 PM
Copyright ©1999-2017 diyAudio
