diyAudio Sponsor
Old 15th January 2006, 09:40 AM   #1
tAB is offline tAB  Hungary
Send a message via MSN to tAB
Default Problems with cathodine
Hi!
I built a driver for PL500. The schema and the pictures of the cathodine signals is in the attachment. The upper side of cathodine has a big distortion
I was tried with other tube, but nothing changed.
If I pull out the second ECC85, the two signal is full symmetric.
What's the problem?
Old 15th January 2006, 09:52 AM   #2
Geek's Avatar
Some first impressions - R10, R13, C2 and C3 are all too big.
You have 1M gridleaks on the second ECC85 - make them 100K to 220K and C2, C3 0.1uF and try again.
Old 15th January 2006, 10:51 AM   #3
Ok. Thx. I'll try it now.
Old 15th January 2006, 11:36 AM   #4
I tried it.
I soldered a 180k paralell with the two 1M, and replaced the 1uF with a 100n. On the picture, you can see that the anode signal have biger distortion.
Old 15th January 2006, 11:59 AM   #5
SY's Avatar
Clearly, the last stage is the issue- you're drawing grid current. Check wiring first. Do a DC voltage map (real voltages, not sims).
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 15th January 2006, 03:21 PM   #6
I checked the wiring, about 10 times
On the pic, you can see the real voltages with red, I think that's OK.
________________
tAB
Old 15th January 2006, 03:55 PM   #7
SY's Avatar
Is that 137V plate to cathode or plate to ground?
Old 15th January 2006, 04:12 PM   #8
137V plate to cathode. Voltage of VM3.
Old 16th January 2006, 11:31 AM   #9
jane is offline jane  Norway
jane's Avatar
I agree with SY, you are drawing grid current in the last stage..
What is the voltage over R14, about 2.3v?
Life is hard - Then you die.
Old 16th January 2006, 08:05 PM   #10
And what can I do?
I'll check it tomorrow.
_____________
Thx, tAB
Cathodyne Questions dsavitsk Tubes / Valves 7 28th June 2009 07:36 PM
Can you use a MOSFET as a cathodyne aardvarkash10 Tubes / Valves 6 14th February 2009 11:11 PM
Cathodyne follower? :) mashaffer Tubes / Valves 6 16th February 2008 08:18 PM
Problem: attenuation after cathodyne and CF diegot Tubes / Valves 2 7th December 2007 06:05 AM
Cathodyne phase splitter with CCS? andrew_whitham Tubes / Valves 42 1st February 2007 09:07 PM
Page generated in 0.10376 seconds (77.12% PHP - 22.88% MySQL) with 11 queries
