| diyAudio Sponsor | ||
guys
refering to Broskies version of PF: in his article he uses just a resistor from 300B plate to before coupling cap in effect the driver's plate and gives the maths for calculating R http://www.tubecad.com/march2001/page8.html in t.rex he uses 47K followed by 2.2uf from 300B plate to 300B grid http://www.enjoythemusic.com/magazin.../trex/fig1.jpg does anyone have an opinion as to why the two topologies and in the second instance how he calculated C looking forward dave dove |
#3 |
SY
i just tried it and it works fine try this: http://www.blackdahlia.com/html/tip_50.html dave dove |
#4 |
Hey-Hey!!!,
I have not read the article in question. I do use the general topology quite extensively in one form or another. Make sure the provided math accounts for the plate Z of the driver tube. The plate resistance forms a voltage divider and the NFB amount is reduced. Pentode drivers are excellent choices, and for the same reason, the cascode. One can also do away with the driver stage voltage supply speerate NFB resistor, and go to a tap on the OPTx plate winding. This is the nuts and bolts to the E-Linear topology. I enclosed a basic PP schematic. cheers, Douglas
the Tnuctipun will return |
| Partial Feedback EL84PP - Not quite as expected (yet) | Svein_B | Tubes / Valves | 44 | 18th May 2008 04:59 PM |
| Partial feedback confusion | Jeb-D. | Tubes / Valves | 4 | 22nd April 2008 05:20 PM |
| Partial feedback DHP SE amp | Fuling | Tubes / Valves | 21 | 5th August 2005 09:20 AM |
| Partial Feedback Amplifiers | audiousername | Tubes / Valves | 130 | 23rd May 2005 07:03 AM |
| Page generated in 0.07595 seconds (73.15% PHP - 26.85% MySQL) with 11 queries |
