diyAudio Sponsor
Old 14th January 2006, 06:26 AM   #1
ardan77 is offline ardan77  Romania
Default replace 5y3
Hy,
I want to do this guitar amplifier and i don't have the 5y3 so i think to replace him with some 1n4007 but i don't know how.
So please help me.
Old 14th January 2006, 09:18 AM   #2
Geek's Avatar
Using 1N4007 with 100R, 10W resistors in series with each on the AC side is the standard practise, IIRC.
Old 14th January 2006, 09:21 AM   #3
as far as i know
(pls correct me if i'm wrong!)
1. lose the heater winding.
2. use center tap on mains secondary
3. replace rectifier with SS diode, both in the direction of the circuit, one on each leg of mains secondary (1n4007,byw96d)
4, -you could use a higher value for the input cap-
5. -you might need an extra resistor before the input cap, due to a higher voltage because of using SS diodes-
6. use a standby switch to let the tubes heat before applying HV
that's it...
you don't have a slow turn on of HV now.....
-hey greg!! you beat me with typing! ......
emission over emittor
Old 14th January 2006, 08:27 PM   #4
Thank you for yours reply
But i don't understand i have to put the 100ohm resistors in series with every diode, and where i put the standby switch?
Old 14th January 2006, 10:54 PM   #5
The reason for putting 100 ohm resistors in series with the diodes is that sand rectifiers have a lower voltage drop (approx .7 volt) than their hollow state forebearers, which have a voltage drop measured in volts.
Take the centre tap from the high voltage winding on the transformer, remove it from where it's connected, and connect it to one terminal of the standby switch, and connect the other terminal of the switch to where the centre tap was connected.
The next time you turn the amp on, turn on the main switch, wait about 30 seconds, and then turn on the standby switch and enjoy the toob sound.
Give a man a fish and he'll eat for a day. Teach him to fish, and he'll sit in a boat all day long drinking beer.
Old 15th January 2006, 03:41 AM   #6
kevinkr's Avatar
You might want to reconsider and possibly just purchase a 5Y3, the sound will differ significantly if you switch to solid state rectifiers.
www.kta-hifi.net
replace DAC maxpou Digital Source 13 21st February 2008 05:51 PM
Replace transistors huy801 Solid State 3 8th February 2008 04:01 AM
Replace of CDM 4/19 with CDM 4/31? bezobraznia Digital Source 4 14th November 2005 03:56 PM
what do I replace...? 9am53 Tubes / Valves 10 5th May 2005 02:20 AM
Page generated in 0.08714 seconds (76.34% PHP - 23.66% MySQL) with 11 queries
